Turn the compound 90 degrees so that the dial is facing you. Both cross feed dial is facing you too. The quick retract level will pull the threading tool
bit out of the cut at 90 degrees. Good for a full profile bit.
What about for a partial profile bit? When the trough of the thread needs to be made wider. What then? There is no more X adjustment, only Y.
