Cole2534
- Sep 10, 2010
- Oklahoma City, OK
How are you guys indicating drills in your lathe turret? I can never get them dialed as well as I'd like and this can lead to a bell mouth hole in some cases. Let's assume they're twist drills being held in ER collets, 2 axis lathe with no live tools, attempting to get all 6 bores centers on x0.
I've tried indicating the turret bore, indicating the holder's taper, indicating a pin in a collet, using the tool probe with a pin and just eyeballing it. So far, the MK1 eyeball has provided the best solution being suitably accurate and fast but this doesn't seem like best practice. My attempts with the indicator never seem to be quite right (this probably means the turret needs aligned, but it turns straight). By not right I mean the drill point doesn't meet the center of the material.
The turret has 1.5" holes, bushings to 1" for the straight shanks on ER16 and 32 holders.
The drills seem straight when rolled across the surface plate.
The end goal is to set the 6 round tool positions X0 and only change the Z0 as I swap tools. Perhaps this is unreasonable?
Thanks crew.
Thanks crew.
