Elemental_Garage
- Jan 12, 2023
Hello all,
I'm in the process of designing/milling a coolant overflow reservoir for an auto project. I have it in 4 pieces; the cap with external threads, a weld-ring with internal threads (this will get welded to next part), the main body which will just be tubing, and the bottom that will be tapped for a drain plug.
The threads I'm making at 2 3/8"-12. For my test cut I used the largest single-form thread mill I had, which is designed for a 1/2 thread. I see that Harvey has single-points going up to 1", but nothing beyond that. My test cap and weld ring actually came out better than I thought, however about half-way through threading it becomes overly tight. I think I made the tolerances too tight. I was limited in the PDO I could use to make the threads deep because I'd run into the tool body. I made the PDO of the internal threads a bit deeper than external, but likely not deep enough.
I'm curious though if anyone has tips on doing these larger threads where you're making both the internal/external threads. I acknowledge the tool I am using wouldn't likely make threads that would engage with a standard 2 3/8"-12 piece due to thread depth, but I also know I can't spend $200 multiple times over for each size and need to find something that will work well in these 2-3" range of making threads, if that makes sense.
Any tips/tricks/points for both process and tooling. I'm using Fusion. I'm also wondering if I had my speeds/feeds right to make clean cuts. I programmed it for the recommended tooth load (0.00068), but I can't get to the SFM recommended with my 6,000 RPM limit.
Here is the test part:
