Koosie
- Nov 29, 2022
- La Motte, Iowa
Hi I don't post here alot but this is my go to for Haas issues. I can usually find that someone else has had the same issue and I can get an answer without asking.
Awhile back I bought a toolroom mill 2006 vintage. It came with a dorky 1/8 horse grays mills coolant pump and a pretty sweet coolant ring made by redbone tool. I found the flow and pressure of this system to be piss poor at best and immediately wanted more. I decided to hotrod the pump and if I burned it up who cares. To me the plastic impeller was far to small and sloppy in the housing so I made one that was larger and "looked about right" to me with a closer fit. Now I have acceptable coolant don't have to babysit pockets with air hose. I've been running it this way and it seems like the motor is going to take it. It gets just warm to the touch after a lot of use.
Just thought I'd throw it up as an option for tm or tl owner's.
