Toe-Jacks: recommendations?
Spud
Jan 12, 2006
Brookfield, Wisconsin
what machines are you buying? if its not big stuff you probably don't need one.
I've moved a few machines, watched a bunch more being moved by pros. I've never needed a toe jack, and I can't recall seeing one used on anything small (under 3T or so). could have used one on a few occasions, but a heel bar and some dunnage gets stuff up, and a J bar or just blocks under the heel, and keep going till its high enough for some wheels. takes a few minuets, no big deal.
if you have one day to clean out a place with 20 CNCs, well that's different, better bring some gear.
About 2 months ago I got an older Hauser jig borer locally. Was wondering how I was going to load it because auctioneer / seller said no loading help onsite. The machine was sitting on 0.5" pads on the ground. The seller did end up loading it for me, but if he hadn't I would have had to lift it up to get skates underneath, to get it close to the shop rollu door or outside so that a boom outfitted tow-truck could put it in my pickup. The Hauser weighs around 2000 lbs I think.
guythatbrews
Dec 14, 2017
MO, USA
You can really do a lot with a pinch point bar and a handful of steel and wooden shims. Johnson bars are also very helpful. A cheaper solution than jacks.
I've used the enerpac flat cylinders but you have to be careful of eccentric loads. The piston can tilt and jam in the cylinder, or at least get screwed up.
I've coveted covered railroad jacks, but figured the top structure would get in the way too much.
Never trust anything. No fingers or hands in the pinch point if you don't want to loose them!
eKretz
Diamond; Mod Squad
Mar 27, 2005
Northwest Indiana, USA
These are what I was talking about. No tilting or jamming that I've encountered:
beckerkumm
Aug 5, 2014
Wisconsin Rapids WI
Since I'm usually working alone, I find toe jacks very useful for final positioning. The forklift does the primary moving but fitting a machine into its final resting place takes toe jacks and machine rollers. I can usually get my 5-8K machines shifted by myself. I have some Hillman rollers I bought used and cleaned up and two 10/20T Vevor jacks. the Vevor are typical chinese $200 each bottle jacks with a casting but they don't get used more than twice a year. I oversized them to compensate for my distaste of cheap crap and so far they have worked well on my heaviest machine, a 16x54 Monarch Lathe. Dave
metalmagpie
May 22, 2006
Seattle
I've had to put my Bridgeport on 4x4's a couple times to move them. While maybe easier with a toe jack, I wouldn't buy one for an occasional move.
-Pry bar to get it high enough to be on 3/4" plywood. In my case "pry bar" was a 1/2" steel rod sticking out of a 3' piece of black pipe because it's what I had. Another pipe or a 1" piece of hardwood scrap for the fulcrum.
-Same pry bar with a 2x4 fulcrum to now get a a 2x4 under the corners.
-Repeat on the back.
-Throw another 2x4 under your fulcrum and go up another layer to fit the 4x4s.
If you need a lever longer than 3 feet you will want a helper to shove the blocks under for you.
I wouldn't want to move a large shop this way, or a 20k pound machine, but for something like a garage sized lathe or mill it works just fine.
If you want to lift the back of a Bridgeport, take your 4 ton porta power and put a bunch of extensions on the ram. Hold it upright beneath the rear lug and pump. It will lift off the ground sweetly.
cyanidekid
Jun 4, 2016
Brooklyn NYC
there is some ambiguity as to the callout on this bar, but this is what the pros use;
sometimes called a bent slate bar, sometimes a pinch bar. the important characteristics are the heavy (1 1/4+) square shank behind the "heel", forged tapered handle, narrow stout chisel point.
some calling themselves such are forged from hex bar, that's not really good enough. some have wide chisel tips, generally not good either.
basically any machine sitting flat on the floor has somewhere to apply one of these, and even if you're going to use a toe jack, you typically
start with this.
eKretz
Diamond; Mod Squad
Mar 27, 2005
I have used those plenty too, but they often require two people. One to hump the bar and another to place the blocks. On heavier stuff it's hard to hold the bar end down and place the blocks at the same time by one's self.
dalmatiangirl61
Jan 31, 2011
BFE Nevada/San Marcos Tx
A cheap toe jack is half the price, on the other hand a prybar won't blow a seal. I have a whole selection of big prybars that I used to use for moving machines, they are collecting dust in the corner today, hope I never need them again. In my opinion prybars work ok IF there is room to use them, and you have enough posterior counterweight. I've danced on the end of a bar without lifting the machine on several occasions.
cyanidekid
Jun 4, 2016
Brooklyn NYC
important thing is its not just a "big prybar". lots of prybars don't have the rigidity and short toe of these and just don't work well on heavy stuff.
regular crow bars in particular, but whatever works for you.
I don't seen how you would never need a prybar if you move machines myself.
cyanidekid
Jun 4, 2016
Brooklyn NYC
absolutely. shouldn't be moving heavy stuff by one's self anyway..(yea, I know, we do it all the time..;))
dalmatiangirl61
Jan 31, 2011
My prybar collection includes bars 5' to 6' long, several styles, including a few bent ones.... I can use them outside the shop to get a machine on blocks high enough to get the toejack under them, but once inside there is just not enough room. The crowbars are used occasionally, they seem to work best for demolition jobs.
cyanidekid
Jun 4, 2016
Brooklyn NYC
man, my shop is jammed, but I can still swing a bar here and there, but hey, far be it for me to contradict another guys "need" for any tool or equipment, ;)
having said that, I have used a 2 1/2 T floor jack to raise up the Graziano SAG 17 to get wheels under it once it's against the wall, but at 3950 it's a lightweight for it's swing, being "raised in the sand". toe jacks would have been a PIA to use for that, would have needed at least two, and I'd have had to clear space to get them on the backside of the headstock.
bottom line, jockeying heavy(ish) shit around is an art, and what we end up juryrigging and such is endless.
I think its a "ton" (sorry..) of fun myself.
bottom line, whatever works AND is safe, go for it!
Toolmaker51
Jan 13, 2009
West MO
I have a pile of 16 gauge cold rolled shims. Had galvanized earlier but those are slippery; in jacking, friction is our friend. Next increment is 1/2" CDX construction offcuts, I broke them down into 5" x 7"'s. Aluminum wedges work once pinch bars are getting a bite, once again, not slippery. They are fairly shallow, not sharper than 1/8" at tip, 11" long around 2" high. Bandsawing is ideal. With a little arithmetic they make good gauges during initial leveling (screw pitch x amount of change) too. I have a set of Tsubaki skates needing turn plates, but ok for straight directions, until then, my go-to rollers? Foosball axles! Minimum jacking and plenty to be on three while the handful are placed ahead. The plating makes them surprisingly durable. If traversing gravel, I have another trick; landscape peeler cores. They are round (kind of) white wood in 8' lengths, some cut for 3' & 5'. Being not identical that makes them roll easy, and little stones just embed instead identifying as wheel chocks. In this move, stretchers connect the feet, no fork lift on site. Worked on 36" gap shear too. At threshold of tilt trailer, I have a winch mounted on a receiver, just crank away. Many of these came about faced bringing in a 4' x 11" radial drill. That high center of gravity stuff needs very careful work.
