If you hire an employee you have a cost if you buy a machine you get a deduction plus an asset.
Biziness financing 101 via Oxman:
They are both a deduction of same value. Although the machine cost may be ammoritised over up to 7 yrs as opposed to annual payroll expences.
Pro: The asset remark can be true. (but not always)
Con: You can't lay off the equipment.
Wildcards:
1) If the market tanks (been there a cpl times in the last 10 yrs) you can lay off the employees. (Didn't have eny employees during either tank.)
2) You cannot "lay-off" the equipment without at the very least messing up your credit, and possibly losing it all.
3) When the market tanks, the equipment that you have 70% payed off may not fetch even 30% original value enymore doo to extreem downturn. I
HAVE seen this scenario all too much in the last 10 yrs! The more generic the equipment - the less likely to git pinched tho. ???
Reality is that employing is safer for the short term. Likely will make you non-competative in the long run. One could run you outta biziness in the short term. The other WILL run you outta biziness in the long term.
When you decide to invest in that big purchase - it will likely make you very vulnerable in the immediate term. As time goes you can git a wee bit of breathing room. It is not 100% guaranteed, but the likelyhood is high that if you always are on the edge of falling off - eventually the market will crash while your looking over the edge.
On that note tho - I will say that I alone with enough equipment have grossed the same annual sales for many yrs now as I did when I had 3 full time guys running O/T continuously. At least as much $ has went to machine payments as would have been hired labor. Eventually it should turn the other way tho .... I hope....
Think Snow Eh!
Ox
