ratbldr427
- Mar 21, 2006
- jacksonville,fl.
I'm in the process of modifing some equipment to use some wound wire torsion springs instead of the flat torsion bars currently used. I understand the basics but need something explaining life cycle , fatigue, end mounting design and material.
What I am trying to come up with is something that will last 20million cycles in 2-3 years. They will fit over a 20mm tube with a total 80 in lbs torque over 40deg. I ordered some cheap McMaster Carr ones for testing but need more engineering data. I may have to make a test rig but don't want to test every combo available , reinvent the wheel so to speak.
The currant bars break at 1-1/2 years ,15 mil cycles. Engineering problem that can't be fixed. They last just past the warranty and the complete assy is 24k ea, 14 used in each machine .
