Hi all,
We are currently trying to transition from using negative tool offsets to using positive tool offsets on our machines. Please see the attached link.
Positive tool offset is measuring the tool from the gage line. See image below.
Negative Tool Offsets look like this. See picture below:
We have a Zoller Venturion 450 tool setter where the tool length is measured outside the machine. The zoller tool setter measures tool length from gage line thus using positive tool offsets. However, I take it that in order to use positive tool offsets, you must have Renishaw probes to measure G54 Z since it is measured from the gage line of the machine to the top of the part and a renishaw probe can quickly do this.
However, we have some older Fadals, Makinos, and an old Kitamura that do not have renishaw probes so we have been using negative tool offsets for those machines (setting our tool offsets and G54 Z from a 123 block in the machine).
We would like to use positive tool offsets for these machines but do not want to buy expensive Renishaw probes for them. What is a quick workaround for this? I was thinking of possibly buying a Haff and Schneider 3D taster (see below). The procedure would involve picking up Z on the workpiece with the 3D taster (zeroing out needle on top of workpiece) and have a macro in the controller do the following: (Z value measured by 3D taster when needle is @ zero + gage length of 3D taster when needle is @ zero) = G54 Z value.
Does this seem like a good solution of measuring G54 Z without renishaw probes?
What is everyone's thoughts?
Thanks,
Chris
Lesson 5: Everything about CNC Tool Length Offsets. Positive and Negative (G43 g-code, H offset) | HSM Machining
Resources and Software For High-Performance CNC Machinists
zero-divide.net
Thanks,
Chris
