Tsubaki Machinery Skates; anyone read Japanese?
Toolmaker51
Jan 13, 2009
West MO
Scored a set of four, visually they may equal 12,000 pound capacity skates. Naturally, I'd rather be certain. The info will aid making turnplates, simply scaling quality like-sized counterparts. each of 4 have same label, pic one has barely visible marking TUF "6" and 58-12; they could be December 1958, yet run smooth, so......
Toolmaker51
Jan 13, 2009
West MO
Thanks, good tip, hadn't occurred to me. I use "Lens" occasionally, with occasional disappointing results Hilarious to me that it struggles with items, seemingly common, that if those didn't exist LOTS of others wouldn't either. But enough rant, I'll give it a shot.
First Round; English and unknown labels, not translated, and spectacular review of every piece of yellow gear [Caterpillar, Komatsu, Duetz, 100's of others] for sale on Earth.
Apr 14, 2018
Totalitarian Ruling Capital, EastAsia
I'll send it over to the japanese teacher I know, but it's still spring festival so no guarantees on timeliness. For all I know she's been drunk on sake for the past three days and whooping it ... maybe better shut up but yes I wou ... umm, I'm leaving now. If I get an answer will tell you.
Kingbob
Dec 1, 2009
Louisiana
This is what google lens could do for me, Looks like you were right on the date - looks like the capacity would be that far right white box
Toolmaker51
Jan 13, 2009
West MO
KingBob, I truly appreciate that effort. My tries got some off that, but haven't figured how to move the cursor/ search box. Putting together a labeled pic is very considerate.
This is more fun than I expected. FWIW, "Lens" can (might) decipher but can't tell what it likes, or limitations. It did a bit of this. Glad this has potential of 6T, the imported 12,000# have tires, I've got more confidence in caterpillar rollers, my floor is solid but may have been poured before 1900. There are uneven sections. I'm cogitating how to construct turnplates, at the moment jacking and hand turning is OK. Those will use corner holes as 'dowels' instead of machine work on skate chassis.
"Translate", have to use more to get familiar, not very intuitive, fiddly too.
Now, about that inebriated language teacher.........
Toolmaker51
Jan 13, 2009
West MO
Nice find indeed.
Google hasn't hadn't indicated Tsubaki made skates; was thinking they're a private label arrangement. Either way, used load skates enough to realize I had to get a set, as usually working alone.
I swear, the four were $100 and a 3 hour round trip.
danker; Thank's for the bookmark! TUF-6 right there in the menu!
I'll be posting while zeroing in on turnplates design, and steering bar.
ps: CAD PDF advises holes in sideplates are not handle attachments, explaining lack of turnplates. While I believe them, also positive a Gr8 or DIN12.8 through bolt with minimum thread length and a snug standoff between the plates will be fine.
Toolmaker51
Jan 13, 2009
West MO
Soy Sauce lacks sufficient viscosity; I'm using Oyster Plum Sauce.
btw, in Asian culture, there is disdain for soy sauce among higher levels of society.
slnielsen
Nov 26, 2004
Viborg, Denmark, Europe
I don't think it looks like something made in 1958. In this thread the OP tells about Japanese years, Showa 58 would make it 1983. The labels looks newer than 1958 to me?
Garwood
Oct 10, 2009
Oregon
Those look like they are intended to bolt to something permanently.
IMO. I would not put turntables on top. I would put rubber pads and link bar sockets on two of them and build the other two into a steering skate like GKS.
  • Like
Reactions: twr
Toolmaker51
Jan 13, 2009
West MO
Ran across Bakafish last night, I posted sincere appreciation toward Japanese products in his post, tools in particular. They have a terrific foundation on machine tools too.
General MacArthur, W. Edwards Deming and Josef M. Duran did the job very well.
I wouldn't give some of their neighbors an inch.
twr
Mar 18, 2014
Kitchener Ont. Canada
Hi i would make the 2 into one like Garwood suggested, thats what i did. Rubber is not glued to the pad yet in the picture. It has a one inch hole in the hitch part so i can hook onto it with my truck or if i had a forklift. Also most of the ones you can buy like this use a large thrust bearing under the pad. Mine has 2 taper roller bearings.
Toolmaker51
Jan 13, 2009
West MO
Aha. Very tactical solution, no floor flat enough to bear on 4 corners, as mere strategists would insist.
I'd rather go in early or stay late, than have looky-loos holding up Olympic scorecards.
Who finds it tedious paying pretend attention to some idgit in slacks and loafers, theorizing what the subject of their attention has completed many times, relying on no distractions.
Toolmaker51
Jan 13, 2009
West MO
Agreed.
As a Showa 27, they are far better off than a mere 6 year age difference.
But 1983 is still along time ago!
Bill D
Apr 1, 2004
Modesto, CA USA
I would assume any weight would be in metric tons or kilos. How does Japan use commas in long numbers? America uses commas to seperate every 1000 and a point for a decimal. Europe reverses this usage.
