Our CNC Department makes what we call chucks, parts that are threaded on one end and have a boss to locate them in their final resting place. They are then turned around held by a solid diameter, and then a hole drilled into the non-threaded end. The problem is the drilled hole runs out from .0005 which is acceptable to .005 which is unacceptable.
Is there a way to turn a threaded part around and thread it into a threaded work holder that had been trued up so that a hole doesn't run out when drilled? Sounds like a lot to ask for but can this be done so we don't have to drill the holes as a secondary operation. Thanks
