turning vertical mill head 90 degrees
monarch1973
Jan 22, 2022
Hey all. I have always used my vertical mill in the vertical position. I have a cast front tractor differential housing that the mounting ears are worn heavily. I plan to bore them out to 2 3/4" with an end mill, and press a bushing in to bring it back to original. Its pretty big and heavy, and I cannot figure out a good way to fixture it so I can mill it out vertically. If I was able to turn my head 90 degrees to be horizontal, I could just set the housing on my table and bore them out. Its a knock off Grizzly brand bridge port style.
Gordon Heaton
Feb 19, 2007
St. George, Utah
You can do that if you have enough table and travel remaining to mount the part and do the work. A right-angle adapter usually leaves more room to work and is more easily dialed in.
GregSY
Jan 1, 2005
Houston
In some cases you can make a horseshoe shaped setup jig that allows you to hang the part off the side of the table, then rotate and extend the head (still vertical) to the proper position. The horseshoe piece can be made of something like 1" steel plate, parallel ground for flatness.
monarch1973
Jan 22, 2022
I dont really have the time for this, but Id like to see a picture for possible future jobs? He brought this to me Friday afternoon and wants it Monday. Everything is an emergency with this business!
monarch1973
Jan 22, 2022
Ok, im going to give it a try. I was just checking to make sure accuracy doesn't fall way off, or its very hard on the machine before I got sideways with this job figuratively.
Bill D
Apr 1, 2004
Modesto, CA USA
Before I did this I would run it up to speed and make sure it has oil at all the points that need oil. Then turn the head and use it. I have no idea if some bearings etc are total loss for oil and if so how that works at 90 degrees.
Better safe then sorry.
Bill D.
GregSY
Jan 1, 2005
Houston
I don't have a pic handy, sorry.
The problem tipping the head 90 degrees is it becomes more time consuming (difficult) to indicate the spindle perpendicular to the bore of whatever you are going to oversize. You lose the benefit of having the spindle/table relationship that you had when it was vertical. Yes, you can get it all squared up but it's more cumbersome.
Without a pic of the housing you are working, it's hard to make any better suggestions.
winger
Dec 28, 2005
portage county, wisconsin
2 3/4" end mill on a Bridgeport????
Your going to need a boring head and enough parallels to get it to spindle height.
Hanging off the side and swiveling the turret over might be easier.
Dave
monarch1973
Jan 22, 2022
I got it bored out. I ended up turning the head. I tried to hang it off the side, but its just a really weird cast shape that I couldnt figure out how to hang onto it and be confident it didnt shift on me.
MaxPrairie
Jul 9, 2015
Charge enough so you almost feel bad about it if it’s an inconvenience and see how big of an emergency it still is to him.
