Hertz
- Apr 27, 2009
- Sudbury, Ontario, Canada
Good morning,
I have a CNC Lathe that we just acquired from an old shop that closed down. It's a BV560MG with a Fanuc 21i Controller with guide mode(Conversational)
The machine seems to work fine for the most part, except for the turret giving me a hard time.
When I try to rotate it, it gives me the alarm 1030 Turret Rotation Fault.
The problem I face is that 1030 isn't in my manuals at all.
I referred to the machine manual, and it had a note that said "If, after switching on the machine, the turret is not clamped or positioned in the wrong position, you have to position the turret again. Refer to 11.3 Chapter in "Manual Mode"
When I go to that section, there is a blank cover page only, so I'm kind of stuck at the moment. I did email the manufacturer but he is on holidays so thought I'd try my luck here. Any recommendations?
If it helps at all, the turret has some numbers on it which I have found online, but nothing about fixing the fault.
TYP 0.5.901.020
ID 077698
COM# 15-00.8194315
TYP 0.5.901.020
ID 077698
COM# 15-00.8194315
