Uberti 1885 High Wall Trigger
Sparky45
Jan 20, 2020
Long story short; sent my High Wall off to be re-bored; got it back and loaded up some ammo to sight her in. Got at the bench, positioned, shouldered the rifle and just touched the trigger and BOOM! Went back to the shop and tested the trigger pull; consistently 1.5#. When I sent her off, the trigger pull was between 4.5 ~ and 5#. All the screws are tight on the trigger spring, hammer spring, and lever spring. What the heck is the reason for the "hair trigger" I now have??
GGaskill
Feb 14, 2001
Central AZ
I am not familiar with the rifle so I would start with the user manual. If you can't get a clue from that, I would inquire of the person who did the work.
Sparky45
Jan 20, 2020
The owners manual has a schematic of parts and a description of how to safely load the rifle. The smith that did the work doesn't know.
CalG
Dec 30, 2008
Vt USA
Well , You have posted on other forums,
Have you tried placing a spring behind the trigger?
Sparky45
Jan 20, 2020
I'm leaning towards the spring being out of position. I'm the second owner of the rifle and I know the original owner and there's been NO stoning of the trigger or hammer, or sear.
I need a detailed picture of the trigger spring correctly in place.
Thanks for the suggestions, I appreciate it!
Sparky45
Jan 20, 2020
Got a replacement trigger spring ordered should be here last of the week, hope that fixes the trigger pull.
Sparky45
Jan 20, 2020
Got the parts and within 15 minutes they were installed and the trigger pull is now a crisp ~4.5#. Couldn't ask for better.
jmm03
Aug 8, 2004
ventura,ca.usa
Sparky, was the original spring weak or in the wrong position? I don't have an Uberti but I wonder if my Browning 1885 is similar in construction. Glad you got it fixed . Jim
Sparky45
Jan 20, 2020
I would imagine your Browning is very similar. Some (1885's) were made with leaf trigger springs and some with coil, as I understand. My 1885's problem was the wrong spring in the gun and the new spring works great.
jmm03
Aug 8, 2004
ventura,ca.usa
mine is the coil type, it is a completely different mechanism than the original as far as I have read, I am not in a hurry to do anything with it really, mainly curious. Glad you got it fixed reasonably. Jim
