cameraman
- Nov 24, 2014
Sounds like you guys are very insecure with your choice and are looking for a way to justify the decision you feel was poor so you come into the thread that has nothing to do with Mikron and start justifying your choice to make yourself feel better.
Nobody in their right mind pays $320k for UMC-500. You can spin that until you faint. It just isn't true. Comparable Mikron is at least double. We paid ~$138k for UMC-500 with 50 tools, high pressure coolant, through spindle coolant and air, belt type chip conveyor, 15k spindle, auto-coolant refill, spare M-codes and bunch of other stuff.
Mikron 3+2, 12k, 30 tools is ~$247k, no through spindle coolant, auto-refill, etc. etc.
Lets get back to the topic of how to solve Z-axis growth in UMC-500. Mikron and other machines should be discussed in separate thread.
YES :-)
___________________________________________________________
BTW there is no Agie Charmilles / Mikron sub-forum here on PM (Forum) [AFIK] , maybe moderators / owners might create one ?
Thought about starting a "Fireside chat" Mikron "Entry level" 5 axis thread but honestly there's no good place to put that.
~ Personally I think the pre-fix or moniker of "Entry level" in RE: 5 axis should be dropped all together.
Some point will comb back over the machine alignment and specific kinematic process(es) for HAAS UMC 500.
_________________________________________________________________________________________________________________
Really interesting what @D Nelson was mentioning in terms of movement.
The reason I "Check in" with Makino is they tend to be a good "Goto" in some cases of HOW to do things or in some cases "How" things should or could or can be done.
The one thing they bang on about a lot (in a machine neutral way) is how various castings and large machine components take up heat and then re-radiate and conduct it out.
Usually they point to asymmetric machines with a lot of diagonal braces and trusses in a frame as well as different thicknesses within the walls of various castings. So in the process of heating up and cooling down, a frame can distort based on the different thicknesses of ribs that take up heat and give up heat at different rates*. i.e. surface area to volume ratio ; thinner ribs will loose heat faster than thicker ones / parts of a given casting with different wall thicknesses.
In what @D Nelson described might be elucidated with a time lapse with a thermal imaging camera. + various DTIs around the machine on "Fixed" points however you can create those. (spindle head / ram assembly).
______________
* Some of the Japanese builders propose boxier castings , thicker / more even ribs , fewer diagonal trusses (in some cases will physically insulate or lag the exterior walls of casting to slow down the rate of heat loss / more even temperature smoothing).
OTOH: Hardinge for example have artfully fine tuned and fixed thermal compensation issues by judicious placement of fans through different points in the castings (that turn on and off) on some of their most accurate turning machinery Rather than to elucidate data from ten different sensors in the casting to derive some sort of automated "Global" compensation values.
The HAAS design for the UMC-500 does kinda hark back to or give a "Nod" to more German style universals.
Other than casting redesign - maybe something that could be fixed with something as simple as a fan and a software tweak.
