Somebody said that he used butcher paper under his vise to prevent the creeping vise print stains on the table (underneath the vise).
I used brown shopping bag which is .006 thick. I assumed it would compress equally and all would be ok. But waxed paper is thinner
and not going to soak oil. Or is it better to live with vise prints?
Signed,
Trying to keep metal bright and shinny half my life.
Brush plating nickel, using a DC powersource with voltage and amp control (usually <$200),
brush often just Stainless sheet metal connected to DC power wrapped in cotton
clothe held with rubber band. cotton soaked in chemical
1) to clean metal, often use electro clean is a chemcal dip into small plastic cup and
then rub on part generally <6 volts
2) did in electrode nickel and rub on part again usually <6 volts and you deposit
a nickel coating usually <.0002" often takes many dips of brush and part rubbing
to electroplate more than .001" just dipping brush periodically in chemicals
3) back in the past I would then dip in 3rd gold plating solution then brush / rub on gold
plating to fill scratches in mirror finish cylindrical printing press rolls. by using adhesive
backed sandpaper and or plastic lapping film stuck to ground metal lapping blocks I would
rub the gold plate color off leaving just gold in the scratches. micron sand paper lapping
film can sand to mirror finish although often 400 grit was fine enough.
........ probably can skip the gold as nickel plating being enough for minor corrosion protection
.... think of it as a electric magic marker but rather than red ink rubbing on electroplated
metal...... by the way using masking tape if cannot pull plating off with tape generally
plating stuck on good enough. also used on lathe to build up worn shafts so bearings fit
tight again (plastic tray under to catch chemical drips as part slowly rotates). usually overplate
than grind to size as turning might just peel plating off like aluminum foil tape.
....Sifco been in brush plating business since WW2 I believe
Today’s demanding industrial applications require well-engineered and proven deposits that pose as little risk as possible to both the operator and the environment. Brush plating can be used to apply a variety of nickel deposits including nickel acid, nickel high-speed and sulfamate nickel as...
www.sifcoasc.com
