I may have made a mistake. During my restoration, I realized that my SB was not using balls (or roller) bearing, but rather what seem like an oil (or maybe a plain) bearing for it's underneath dive shaft. I decided to remove the whole assembly (that went relatively well). I'm now at the step of removing the flywheel (or the v belt pulley) to dissasemble the whole thing, but I'm stuck at the taper pin. This is when I made a mistake.
At first, I did not realized it was a taper pin, since the head and was round and the bottom was smashed like a rivet. Therefor, I drilled the the bottom, like I would to remove a rivet, and tried smashing it out. It did not went out. After two our of fighting, I stopped and I decided to drill the pin out on both side of the casting and put a bigger one in when I'm gonna reassemble. To do so, I drilled on both side until I was a little bit in the shaft.
Now, their should not be any pin left to secure the wheel on the shaft, but It's still not coming out. I saw a few video on the restoration of a 9A model, and for those, it seem like the assembly is using a clearance or a locational fit, but on my 117C, I cannot move the thing even with a soft hammer and a few solid blow.
I'm wondering if by drilling these holes, if I did not created an interface where the edge of the shaft and the wheel are meshing, in a way that it prevent me to remove the whole thing, or if the fit on these models are some kind of interference fit.
Either way, I will need to get this shaft out, and I would like to know if someone here managed to get out of a similar situation or if anyone have more information about this particular model and the fitting of the shaft on the wheel.
I'm putting a few picture online, right there :
For the unitiated, it's imgur, a website that let you post large picture for free. I cannot post them here, they are too big.
