zimbo
- Apr 22, 2017
- Richmond, VA
Mornining PMs,/
I would like to understand the relationship of tapered roller bearings and thier placement on the axle of a trailer and hub and distance from the flange. Haven't found much at all out there, unless been asking the wrong question to Mr Google. There has to be some science behind it.
I have been making a few hubs these past 12 months for boat and small trailers and various farm implements out of cast iron.
Comparing the samples that have been coming in with same bearing size, the placement of the bearing seats are slighty different from each other.
Eg. bearing number 18690/18620. The distance from the seal outside edge edge to the flange is 26mm and 32 mm respectivley. The seal is 10mm thick. The flanges are 18-22mm wide, not sure this has any impact other than holding the wheel studs. The bearing sits right upto the seal.
The distance between the outside and inside bearing are vary. I would have thought that the bearings would be equidistant from the flange to absorb the radial load evenly as in the harrow bearing housing. Doesnt seem to be any standards, even the lands on the harrow spools vary from 3/4-1" thick, even in the same bearing size and there are 2 common sizes.
Would appreciate an explaination or a source I can read up on this. Would make my life easier.
Cheers,
Cheers,
