Unidentified Set Screw
sddutch
Oct 4, 2018
I have a CNC engraving machine and one of the tools uses a tiny set screw to hold my engraving cutters in place. Recently the tiny set screw grew wings and launched itself from the machine to points unknown and I need to replace it.
It is 0.25 inches long, 0.125 inches wide, and has a cross "+" head. From what I have been able to find online, I think it is a number 5 set screw, but all of the ones I have been able to find have a 6 sided "hex" head and not the cross type that I need. P5290002.JPG
Can someone identify this set screw and tell me where I can purchase some (See attached .pdf document)?
Thanks.
  • Unidentified Set Screw - Possible Number 5.pdf
L Vanice
Feb 8, 2006
Fort Wayne, IN
That style of drive is called Bristol. You can buy sets of L-shaped Bristol wrenches from the usual industrial tool sellers. I have not looked to see if the screws are available, but now you know what to ask Google.
Of course, the threads and other dimensions would be the same as a hex head version of the screw, which would be much easier to find locally. You could even use Google to search for engraving machine supplies sellers, who would likely sell the OEM screws for a New Hermes or whatever brand of engraver you have.
Larry
awander
Jun 11, 2012
Eastern PA
Sorry, but I just have to ask-why can't you use the set screws with the Allen (six-sided recess)
Larry
head?
L Vanice
Feb 8, 2006
Fort Wayne, IN
Bristol sockets are stronger and much less likely to strip out than Allen (hex) sockets. The engraving machine companies knew that and used the Bristol screws for the cutters because the screws had to be loosened and tightened repeatably in normal use.
If available, Torx head set screws would be a good replacement for the Bristol screws.
Larry
awander
Jun 11, 2012
Eastern PA
Larry
Makes sense, thanks
jim rozen
Feb 26, 2004
peekskill, NY
WW2 aviation electronics use those spline wrench setscrews. If you happen to be a kid trying to convert an old Command set for ham radio use, and are trying to drill one of those out with an eggbeater drill using hardware store drills, trust me it does not go well. Those setscrews are harder than bill-goat dicks.
EPAIII
Nov 23, 2003
Beaumont, TX, USA
If you are still unshure of the thread size, just try some regular screws (Ace Hardware) in the hole to see what matches. Then you can buy the, probably expensive, Bristol head screw in that size.
boslab
Jan 6, 2007
wales.uk
Never encountered Bristol screws in the wild bar once, and they were holding a C60 source in a gamma source, I don’t suppose they wanted people tinkering with that! So it was a kind of security screw,
Mark
GregSY
Jan 1, 2005
Houston
There are really two issues here, and they are not tied to one another. The OP asked for the screw he 'needs'. That would be the screw with the proper thread and to a lesser extent, length. The thread should be first be identified, then the second issue - the type of drive - can be included in the hunt.
A regular Allen head might not be 'ideal' per the designer's directive, but would be way better than the existing Bristol screw which is MIA. So...you buy a box of 100 Allen heads from McMaster and get back to work. Then, as time goes by and the Allen's fall victim to flinging and stripping, you have time to find the Bristol screws and wait for them to arrive from, well, Bristol.
John Garner
Sep 1, 2004
south SF Bay area, California
I've encountered internal-spline-drive setscrews under both "Bristo" and "Bristol" labels, and L-shaped splined drivers for both "Bristo" and "Bristol" setscrews. Anyone here know the story behind the different but oh-so-similar names?
Dan from Oakland
Sep 15, 2005
Oakland, CA
McMaster Carr sells spline drive "hex" wrench sets.
I have a hurco that uses spline drive set screws to attach encoder discs, and MCM was the only place i could fiind the really small sizes.
James H Clark
May 11, 2011
southern in.
To determine what thread you have, you need find out what the minor diameter of the threaded hole is. Then turn a small hardwood dowel to a size a few thousandths larger than the threaded hole. Then screw the dowel into the hole and back out. You can determine the thread markings on the dowel. I usually blacken the dowel before screwing it into the hole.
JH
