Unison Dedtru centerless grinder through feed operation - Wheel recommendation
OMTRandy
Mar 14, 2021
Hi, I recently purchase a Unison Detru centerless grinder to use the through feed process to grind in the OD of some 4" long 1144 stress proof blanks to 0.4995 +/- 0.0005; and to grind in the OD of some 1" long 303 stainless steel blanks to 0.620 +/-0.0005. Can someone recommend the correct wheel size, type, grit, and bond for this application and these materials? Thank you!
RJT
Aug 24, 2006
greensboro,northcarolina
Depending on your wheel guard either a 7 or 8" by 1/2 by 1 1/4 is what we use most of the time for through feed. If the 1144 is soft, 46 H, if it is hard 60J or 80J. For the stainless you need a very porous open wheel, nothing works great, but i would start with 46H. There are wheels specifically for stainless, but we have not had great success with them. They don't load up, but they don't stay dressed long either.
OMTRandy
Mar 14, 2021
Thanks RJT! I will start here and see how it goes.
I bought the Tech Cool 3718 coolant that Unison sells but haven't filled the tank yet. What coolant/oil are you using in your shop?
