Hi All,
For various reasons, I need to upload Work Zero data (G54,G55 co-ordinates etc) from my PC onto my Brother TC-S2B (A00 Control)… rather than manually enter it/set it on the machine…… trouble is I’m having problems uploading this data (I have no problems uploading ordinary programs and do it daily…via RS-232).
I’m able to backup/download this same Work Zero data from the control onto my PC..(and did this so I can see what I think is the format required to upload). An example looks like the code below which has come straight from the control.
If I try and upload this same file to the control (but additionally removing the ‘S’ after the %... as according to the manual that means Slave), I get the following error:
‘7546 LOAD DATA NAME ERROR’ and as it suggests, the manual says ‘The data name of the received header is not correct’. I’ve since tried many other things like renaming it to POSNM2 for example and trying to load it into Metric 2….. but no luck.
Hopefully it’s me just being stupid and there’s a simple solution here….. so if anyone knows what I’m doing wrong and can help, then that would be really appreciated.
Many thanks….. Chris.
(The POSNM1 below is the name of the dataset stored in the Metric 1 directory in the memory on the control).
Here’s the code that came from the control:
%S POSNM1
G54,-90.384,-92.675,112.909,0.000,0.000,0.000
G55,-283.371,-47.801,145.381,0.000,0.000,0.000
G56,-84.600,-180.200,130.922,0.000,0.000,0.000
G57,-93.820,-47.865,80.000,0.000,0.000,0.000
G58,-480.000,-360.000,160.000,0.000,0.000,0.000
G59,-407.302,-47.372,50.000,0.000,0.000,0.000
X01,-198.602,-205.026,142.343,0.000,0.000,0.000
X02,-223.358,-168.670,127.554,0.000,0.000,0.000
X03,-219.975,-131.694,125.631,0.000,0.000,0.000
X04,-34.868,-85.500,115.575,0.000,0.000,0.000
X05,-227.067,-68.064,122.527,0.000,0.000,0.000
X06,-394.144,-67.918,222.289,0.000,0.000,0.000
X07,-54.204,-179.278,166.820,0.000,0.000,0.000
X08,-308.475,-97.250,251.250,0.000,0.000,0.000
X09,-388.388,-97.235,228.652,0.000,0.000,0.000
X10,-353.378,-97.235,214.540,0.000,0.000,0.000
X11,-405.882,-67.310,265.830,0.000,0.000,0.000
X12,-375.932,-200.333,155.975,0.000,0.000,0.000
X13,-424.083,-165.363,220.613,0.000,0.000,0.000
X14,-411.104,-208.987,170.261,0.000,0.000,0.000
X15,-175.175,-47.566,105.915,0.000,0.000,0.000
X16,0.000,0.000,0.000,0.000,0.000,0.000
X17,0.000,0.000,0.000,0.000,0.000,0.000
X18,0.000,0.000,0.000,0.000,0.000,0.000
X19,0.000,0.000,0.000,0.000,0.000,0.000
X20,0.000,0.000,0.000,0.000,0.000,0.000
X21,0.000,0.000,0.000,0.000,0.000,0.000
X22,0.000,0.000,0.000,0.000,0.000,0.000
X23,0.000,0.000,0.000,0.000,0.000,0.000
X24,0.000,0.000,0.000,0.000,0.000,0.000
X25,0.000,0.000,0.000,0.000,0.000,0.000
X26,0.000,0.000,0.000,0.000,0.000,0.000
X27,0.000,0.000,0.000,0.000,0.000,0.000
X28,0.000,0.000,0.000,0.000,0.000,0.000
X29,0.000,0.000,0.000,0.000,0.000,0.000
X30,0.000,0.000,0.000,0.000,0.000,0.000
X31,0.000,0.000,0.000,0.000,0.000,0.000
X32,0.000,0.000,0.000,0.000,0.000,0.000
X33,0.000,0.000,0.000,0.000,0.000,0.000
X34,0.000,0.000,0.000,0.000,0.000,0.000
X35,0.000,0.000,0.000,0.000,0.000,0.000
X36,0.000,0.000,0.000,0.000,0.000,0.000
X37,0.000,0.000,0.000,0.000,0.000,0.000
X38,0.000,0.000,0.000,0.000,0.000,0.000
X39,0.000,0.000,0.000,0.000,0.000,0.000
X40,0.000,0.000,0.000,0.000,0.000,0.000
X41,0.000,0.000,0.000,0.000,0.000,0.000
X42,0.000,0.000,0.000,0.000,0.000,0.000
X43,0.000,0.000,0.000,0.000,0.000,0.000
X44,0.000,0.000,0.000,0.000,0.000,0.000
X45,0.000,0.000,0.000,0.000,0.000,0.000
X46,0.000,0.000,0.000,0.000,0.000,0.000
X47,-113.448,-157.995,77.760,0.000,0.000,0.000
X48,-16.854,-126.518,149.535,0.000,0.000,0.000
%S POSNM1
