solidworks4u
- Apr 23, 2011
- 19970 DE USA
Using 2 spindles to ruff & finish pockets & profiles in 1/8" aluminum plate. Fanuc OM, Supermax2 with mounting on Z axis for 2 spindles, need help understanding machine offset inside Fanuc OM controller and or BobCad v29.
I had success with single spindle and BobCad v29 even though the Post Processor is not perfect. I review each program for the -Z and edit out as to not allow the z axis to go all the way back to "home", (Z axis all the way up) location. By mounting 2 spindles about 9 7/8" (x direction) apart from each other. All the parts are small, all have at least 1 pocket & the profile needs a finish cutting on each part.
To set up, usually the part is against a stop, held in a vise, attached to a tool block with a 1/4" reamed hole to use as the same starting point no matter what the shape of the part is. Using a dial indicator, in the 1/4" reamed hole, to locate each spindle (ruff/finish or Left/Right) in relationship to the machine. It is as follows; Left spindle [X=-13.2410 & Y=-5.9523] & Right spindle [X=-23.1187 & Y=-5.9504].
I believe each of these sets of these dimensions will be used so the controller in the machine offset. In BobCad, I am not shore if there is a way to save any time or make more consistence or allow for fewer mistakes.
Every part has 2 programs, ruff pass will have an additional finish program that requires the operator to turn off or on the spindle to match the type of program to the part. If the cut time becomes short, I will keep the spindle running at low speed.
