solidworks4u
- Apr 23, 2011
- 19970 DE USA
Mike, many thanks! My post processor is not perfect, so I need to revisit the G-code to edit the feed, usually after any G54 in the single spindle programs.
Your suggestion in BobCad is to create a ruff and finish all in 1 program, then edit (I know I need edit feed) then make shore all tool #1 (larger tool) G-code associated with the G54 work offset & all tool #2 (smaller tool) G-code associated with G55 work offset.
I would need a "pause" in the controller, so I can set air, coolant & correct spindle up to speed between the ruff & finish cuts.
If I have understood correctly, this sounds like a plan that I will be working, if something I have overlooked please point it out.
Vanbiker, my screen shows a G53, top left corner of screen, I believe my Fanuc OM is a C version. Many thanks!!
Many, many thanks for the second opinion!
