Where in Canada are you?
Before putting any time or money into an older lathe like yours, I’d want to know condition of rest of lathe. Is it worth it? Could there be other, better condition lathes in your futur
Quebec, around Montreal.
The spindle and its bearing look fine, I think these where the only that where not greased up with god know what.
other than the ways, the cradle and its shaft are badly worn out. Mine is a 1942 model, from before they started using bearing there. I made a post about that too. Fortunately, it should be an easy fix, since it`s just a new shaft and 4 bushing that need to be made.
The gears seem to be fine. Some tooth are visibly thinner than they should be, but they seem alright.
The half nut and the cross slide nut are about to die... these are only a fine wall away to be thru holes. These are on my "to do before they break" list, since these are expensive.
Other than the wear, no rust. Just a load of grease and gunk everywhere, in every orifice imaginable. I hope it's worth it, since this thing is about 3k less than any other lathe in the area.
I just looked up this online, they're in Quebec. They have a surface grinder it says.
https://www.meyertool.com/meyer-tool-canada/
Screw the grinder, I'm gonna have my ways plated back to original thickness with that
https://www.meyertool.com/platinum-plating/
But more seriously, these guys are about 45 min of walk from my place. If they don't charge too much for a good grinding, they would be a good solution.
When you grind a bed with the owner looking on,often they are dismayed that whats being ground away is the good part of the bed............the worst worn part is the last to start to grind,and that doesnt seem right.............and so we have all the u tube videos of guys grinding the scored ways under the chuck until they are nice and clean..........they are actually making the wear worse.
I dont follow you... Are you saying that they don't remove the material at the right spot and doesn't make the ways straight?
If you use a flat way to replace an existing V way, what will then locate the saddle in the X direction?
I was not planning to get rid of the v way. There is two V way for the saddle. one of them is more worn out than the other. If I use the flat way, then the other V way would be entirely responsible for the X direction by supporting both side of the V.
