using turcite
porthos
Sep 12, 2013
western pennsylvania
my 6x48 belt sander has a .016-.018 dip in the center. i was thinking that i could use turcite to "level" it. my thoughts are to spread the turcite epoxy around; then cover it with wax paper. then lay my granite surface plate over it to flatten the epoxy . never used turcite before; any thoughts or suggestions??
TGTool
Sep 22, 2006
Stillwater, Oklahoma
Turcite is a sheet product available in different thicknesses so is not what you need.
You're probably thinking of Moglice, a pourable/spreadable product designed for way lining. I don't know how well it withstands the belt friction and abrasive environment of a belt sander. Others may have some real world experience of restoring sander platens.
johansen
Aug 16, 2014
silverdale wa
Consider an experiment before you waste your time and money.
Buy a sheet of adhesive backed polyethylene in 1/32” thickness and see if it holds up.
Milland
Jul 6, 2006
Hillsboro, New Hampshire
While your thought of using a "Moglice"-like product probably won't work due to rapid wear, you could try using a uniform layer of epoxy in a similar way, but with a layer of spring steel sheet (say .030") as the actual wear surface.
Either align the steel sheet carefully when placing the belt sander over it, or leave it oversize and trim to size afterwards. Be sure to round over the leading and trailing edges to allow the belt to run over them without scraping or excessive bending during use.
Richard King
Jul 12, 2005
Cottage Grove, MN 55016
I wouldn't recommend either Turcite or Moglice to have an sanding belt rub against it. Mattison Surface grinder company filed bankruptcy because Mogice worn down fast and it plugged up the oil holes. Turcite is designed to run against lubricated cast iron ways. That belt would wear it and it would get HOT. Buy some sheet metal and tack weld it on the edges or just make a new part.
wheels17
May 10, 2012
Pittsford, NY
My belt sander has an aluminum platen covered with a spring steel plate backed with about 1/16" cork. Since 1978.
The leading edge of the platen kicks away from the belt at 45 degrees to provide an attachment point for the spring steel.
You could use one of the polymer filling compounds on the platen, and then follow Milland's suggestion.
michiganbuck
Jun 28, 2012
Mt Clemens, Michigan 48035
Qt Op: (my 6x48 belt sander has a .016-.018 dip in the center.)
You might be able to just surface-grind out a small dip
Qt Richard(Buy some sheet metal and tack weld it on the edges)
or just screw the sheet metal plate in place with flat heads, that way you can restore flatness every 15 years or so.
ratbldr427
Mar 21, 2006
jacksonville,fl.
There's a material made just for that .Comes in a roll.Looks kind of like graphite bonded on a canvas belt. Hadn't look at it for awhile. I think I got it from McMaster Carr or MSC. I'm sure if you looked on line you could find it. Belt sander backing pad.
Richard King
Jul 12, 2005
How much did the charge you to grind the bed? Did they grind all the ways. underside of the rear bottom hold down? Or only the top ways. How long did they have it inside their shop? Was there a ridge on the bottom of the saddle, so you can estimate the wear on the saddle? Can you set the saddle upside down on 1 2 3 blocks on the 4 corners of the cross-slide and use a round dowel pin or drill rod about 2" long to set in the V to see if the saddle bottom is worn more on the front chuck side then the front tailstock side. How much Rulon / Turcite are you going to epoxy on? Remember to add in the .003" to .005" for the epoxy. I think the cross slide is fine, just make sure you indicate the saddle in good to make sure the cross-slide and saddle bottom are square or it faces concave about .0002 in 12".
Milland
Jul 6, 2006
Uh, Rich? The Takisawa thread is thataway >>>>
:D
eKretz
Diamond; Mod Squad
Mar 27, 2005
Northwest Indiana, USA
I ground the platen on mine and put a sheet of glass on top. Held it in place with small pan head screws against the edges that don't protrude above the glass.
rke[pler
Feb 19, 2002
Peralta, NM USA
Depending on the thickness of the platen you might just mill some of it away and epoxy in a replacement. A chunk of AR500 would last a good long while. Knife makers who use their 2x72 a lot tend to have a chunk of Pyroceram there since it's hard and abrasion resistant. Here's one shop that custom cuts it for you (no association with me):
eKretz
Diamond; Mod Squad
Mar 27, 2005
That's what I used. Nice thing about that is it's easy to replace if it wears into an out of flat condition again too.
