Shop is 240 volt 3 phase. I have two edm machines using separate 3 phase multitap autotransformers to get from 240v up to 380v. Transformer says 12kva, machines say 10kva.
Just added a third edm machine with the same multitap autotransformer setup. Getting the 380v out is no issue. The question is the chiller unit for this new to me machine needs 480v 3 phase where my other older chillers were 240v and were on the shop standard volts.
On the same multitap autotransformer as the 380v edm can I also pull the 480v for the chiller from the 480v taps as long as I don't exceed the total kva or amp rating for the transformer with the combined loads?
I have used an isolation transformer that has 480/240 with a center tap on one phase so I can also get 110v which is in effect pulling multiple voltages from a sort of multi tap scenario but wasn;t sure about the autotransformer multi tap.
The alternative is to investigate converting the 480v chiller to 240v if its dual wound or provide a separate transformer for it.
