snowman
- Jul 31, 2004
- Southeast Michigan
I have a piece of Schedule 40 14" PVC pipe that I need to make in to a vacuum chamber. One end will be capped with a traditional 14" cap. The other end is the trick. I had originally planned to use a 14" PVC bolt up flange, but holy crap are they expensive. The actual cap will be a flat piece of 1/4" stainless steel. I just need some sort of seal that holds up between the PVC and the steel.
I'm really pretty flexibile in how this is going to be done. It will be exposed to dilute acids though, which makes choosing the sealing parts a little trickier. I've considered buying a piece of polypropylene as a cap, cutting a groove in it for a large viton O ring, then tie rodding it to the bottom to create tension.
Any other ideas?
I end up in similar situations trying to seal up makeshift vacuum chambers for controlled atmosphere metallurgy.
Any other ideas?
