rrrgcy
Member
Have a trepan job and thought (I thought I thought well) to get the ready-made ValCut (used, though one cutter, haven’t tried it yet). A la Swiss the shaft isn’t .500” but a touch chunky (metric) so need to bore or order a bit and ream a holder to 13.5mm. First time I’ve hit that paper wall. I’ve not ground cutters anything like these. Online images and reading and Penn Tool weren’t helpful (they advised contact the manufacturer, yeah sure, no answer archived terrible cust service), but I’d like to know how the cutters differ to cut differing depths since it’s one way they sell them:
Q. Are greater depth cutters with longer scoops/lips and or increased back rake or the actual cutting angle changed to more vertical off the horizontal (bottom)? How are they different? Has anyone ground HSS cutters (my plan) to follow the profile but how-to for thicker material? I need to do 1/4”-1/2” lo-carb steel. The “sheet steel” cutters look the same as do all the others for thicker. I’m wary to buy a set, whether from France Germany (broken sets) or USA (full 5) and would rather just grind some. These are fairly $$$.
