Various cutters, 3"
Toolchanger
Aug 10, 2020
Hi all, looking to offload a few items that I do not have the ability to use. Located in Central IL. Can meet or ship USPS/Fedex. PP, Zelle, or check if no rush. Please message if you have questions!
$65 - (1) Valenite SS3-300-4R15-125F - 3" dia, 1.53" DOC max., 15 tooth helical flute square shoulder, 1.25" arbor, 0.50 keys. Unused without box.
(15) PT-546T Insert screws, new
(10) SPEW43EDTR 935 inserts - used - some with good corners
(10) SPEW43A022A1H 225 inserts - 5 used, 5 new
$95 - (1) Valenite V590 A 13 0300 H09R, 3.00" cutting diameter, 1.00" Arbor plug diameter, 2.0" gage height,0.48" depth of cut max, 9 tooth ,AP1304.. insert size, DVF0943 screw (torx 9 IP) - has 2 extra screw, torx driver, molykote tube, and assembly sheet.
$70 - (1) Valenite M680 sq shoulder mill # 539.63.046 - 3" dia, 1" arbor, 2" gage length, .375 keys. Has 6 slightly used inserts on it. Very good condition. Uses Widia M680 series inserts XPHT33x / XPHT 16 04 xx
$60 - (1) Valenite M660 series face mill 45 deg. 2.5". 3" max 1.5 gage length, 4 tooth. Uses Widia M660 series SN..43x,/SN1205 (0.5in IC Dia, 0.219 thk), like the SNKT-21 or SNKT-20. Includes 4 OEM screws.
