They don't make the Teco-FM100 anymore. They do make a Teco CV-2003-h3 that seems like a full blown PLC to me.
TECO/Westinghouse 7300CV AC Drive, 3 HP, 230V 3 PH Input, 230V 3 PH Output, 10.5FLA, IP20, Frame 2 (JNTHBCBA0003BC-U)
200-230VAC 1 PH, 50/60Hz (Voltage +10% to -10%, Frequency ±5%) Input
Sensorless Vector & V/Hz control modes
Integrated PLC Functions
Built-in PID Control
0-230V, 3 PH Output
1 Analog Input (0-10V, 4-20mA, 0-20mA)
1 Programmable Multi-function Analog Input (0-10V)
7 Programmable Multi-function Digital Inputs
1 Analog Output (0-10VDC)
2 Multi-function Output Relay
Removable Keypad with Potentiometer
4 digit, 7 segment LED display
150% rated current for 1 minute
200% instantaneous overcurrent
Electronic overload protection and stall prevention
Ground fault and short circuit protection
UL 508 / cUL / CE
2 year warranty
They also make a FM50-203-c that seems a little simpler and about a $100 cheaper.
TECO FM50 AC Drive, 3 HP, 230V 1 / 3 PH Input, 230V 3 PH Output, 10.5FLA, IP20
115, 230 and 460V, 50/60Hz (Voltage +10% to -15%, Frequency ±5%) Input
0-230V, 3 PH Output
2 Programmable Multi-function Inputs
2 Operation Control Inputs (FWD/REV)
1 Multi-function Output Relay
3 digit, 7 segment LED display
UL 508 / cUL / CE
2 year warranty
Is it worth the $100 for the extra features?
Thanks
i_r_machinist
