VFD Fan on constantly while powered up
mmurray70
Jan 11, 2003
Hi guys I have another little issue with a Hitachi L200 VFD that i recently installed on a manual lathe. The fan is on constantly while its powered up. I find this very annoying. Is this normal for some VFDs or is there something wrong with it? Id like to change this but I dont want to be switching the VFD on and off all the time as thats not good for them.
Is there a parameter to change this? If not can I hack into it and run the fan wires through the relay outputs and get it to start and stop that way?
mmurray70
Jan 11, 2003
went ahead and ran it through the relay and seems to work fine. even changed a parameter to get it to run for extra 60 seconds after stopping. Some of the other vfds i have work that way so figured it couldnt hurt.
mmurray70
Jan 11, 2003
Doesn't appear to be for my drive. One part of manual does seem to mention something about it, but nothing listed in parameters at all. Seems to be working well now as it is. Bit of a pain but had it all working the way i want in hour or so.
Jraef
Aug 10, 2004
San Francisco Bay Area
Some drives let you control it, some don’t. 60sec may not be long enough though, depending on the load on the drive when you stopped using it. Drives I’ve seen that allow the fan to turn off usually do so after 10 or 15 minutes.
mmurray70
Jan 11, 2003
Thanks for the advice. ill change it to the maximum time allowed.
