VFD reccomendation 15 hp motor
YoungDen
Feb 16, 2004
Kiron IA USA
I have a machine that has been operating with a 10 hp and 5 hp single phase motors belted to it. It has worked OK for years. I am having trouble with the 10 hp motor tripping thermal switch. I have been watching amp draw and it is not overloaded. I wonder if thermal overload switch is weak? I may try a remote overload switch as the motor is 90 feet in the air. Not easy to use IR heat gun to see what temperature is. If the different overload devices don;t solve problem, I will replace with a new 15 hp motor and VFD. What VFD should I look at? I have used VFDs for 25 years but 1 hp is a different commitment than a 30 hp model.The machine can not be used at any speed but motor rated so variable speed is not any value. Maybe just put together a 30 hp idler phase converter?
Look at this.
If the location the motor is in happens to be dusty, the motor may just be choked with dust, Either inside if it is open, or if it is a closed motor, the fins may be thickly coated with dust, etc.
