rons
- Mar 5, 2009
- California, USA
Motion, Jst,
Good advice.
Good advice.
SAF,Ron, I did a little homework for you to see if I could assist. Your pump looks to be an earlier Kellog American type from the photo you provided, based on the head style, crankcase shape, centrifugal unloader and port layout. They used a few different corporate names over the years. From the looks of it, you have a 5HP pump that is over-sped based on your motor sheave size causing your hard start problems.
Get the motor sheave size corrected and keep the ramp up time as short as possible, like 3 sec to keep the overload period from tripping out your drive. As far as motor selection, newer energy efficient motor designs have a much higher inrush current than the older design motors, so you may want to try an older model before the energy efficiency models were mandated.
No it's due to lower air gap, results in higher power factor, lower running amps.SAF,
Is the higher inrush due to less iron? The big difference between a modern and old motor is the weight.
Ron, the differences are due to several factors, but mainly due to better and more materials. Higher efficiency requires lower winding resistance, better steel lamination's for better magnetic permeability and closer manufacturing tolerances. I don't think that you can make a judgement based just on weight, The housing material, cast iron with cooling fins versus a rolled steel would make a large difference in weight, irrespective of other factors. Here is an article that covers some of the differences.SAF,
Pretty sure I already covered that inrush has nothing to do with a VFD because VFDs always run to the right side of the speed torque curve...........Ah, then to make my newer efficient motor with all the newer designed steel less responsive...
I shall mount the rotor on a lathe and take a few thou off the diameter.
Yes, this guy wrote a article on the pro/con of hi-slip/hi-resistance rotors.Shaving the end rings does reduce starting amps. It also increases "slip", so it is a trade-off.
The best rotor is a dual cage.... thinner conductors at the surface for low start amps, and larger buried conductors for low slip. But that is a choice the manufacturer had to make. Not very practical to add later (although it "can be done" in some cases)
I was suggesting it for making a RPC.That used to be done. Wound rotors on induction motors, and external resistors. Yep, set to high resistance, for low start current on your 100HP motor, and reduce resistance as it speeds up.
Not done any more. Costs a lot more than putting a VFD on it, and doesn't give as much benefit.
It was originally designed for 150-175 PSI. At full throttle I could blow a medium heavy rubber door mat off the floor several feet.In addition to the other comments, do you really need 130-150psi? 90 is usually more than enough for air tools and general use. At the higher pressure, your load is probably 70% higher than it need be.
Nobody cares about what the fly on the wall is wondering...Starting to sound like the old lady who swallowed a fly, yes!
Wondering what sort of hobby shop activity NEEDs half that much air?
That part, you've not explained?
But I don' picture you doing large or long duration media blasting?
Money ahead to buy a new, smaller, commodity 1-P C-H unit from Pig Box every few years, maybe?
Notice
