Hi all,
I've had 2 single phase to 3 phase 2.2kw 10A VFDs for several years now with no issues. One on my lathe, one on a mill.
Recently got an INTERMITTENT error of UU undervoltage (on both VFDs). It can run fine for ages then suddenly trip. Sometimes under load, sometimes not. Tried with different motors, makes no difference. I wired up a new (3rd) vfd of same model to the lathe and works fine. Sometimes before it trips you can hear the relay clicking randomly. I believe this relay controls the input single phase voltage charging the capacitors with rectified DC voltage and shorts the high power resistor to stop the charging when full.
Mains voltage is fine and on 32amp breaker.
Unplugged all other equipment on the same ring. No difference.
Opened the VFD and checked the capacitance of the 2 820uf caps which gives approx. 1476uf for both which is low but within 10%.
Unsoldered relay and this seems fine. Coil resistance is ok I think and switches with 24v appied over the coil.
Unsoldered the rectifier and seems to test ok with multimeter.
Checked the resistor on both VFDs, one about 152ohm and the other 158ohm. I assume this should be 150ohm???
I replaced the resister (158ohm reading) with the (152ohm) resistor and put the VFD back together and it worked flawlessly last night. Tried this morning and tripped again. I think this may be due to the motor struggling because I had the lathe setup with the steady a bit too tight. Now it tries to run the motor and just trips again.
Is this because the resistor is getting burnt out and increasing in resistance when hot preventing the capacitors from charging fully (quick enough)?
Model of the VFD is Ecogoo 9100. Manual attached.
