Vibration with toothed pulley
jroddds
Apr 16, 2020
Hey all,
I changed my mill from a poly-V belt to a timed pulley - HTD5. The poly belt was slipping during tapping cycles on larger taps. The timing belt is working great except for one thing:
I am getting a noticible amount of vibration in one specific speed range. Outside of this range, everything is pretty smooth.
The spindle motor is 1750RPM Vector Duty with full HP at 2x speed.
The spindle is geared up 2.2x, giving a speed range of 200-7700RPM.
The vibration ONLY happens between 1700-2100 RPM.
I was wondering if this is a "harmonics" issue with the mill. At that speed it just finds a rhythm.
I have several hours on the machine since changing the pulleys. Hoping the belt would run-in and this was a temporary issue. But not much relief so far.
If you guys have any suggestions, I would welcome them.
Jared
Milland
Jul 6, 2006
Hillsboro, New Hampshire
Could be an acoustic or vibrational resonance. Acoustic due to the right speed allowing the air to squirt out of the closing volume of belt to tooth area in some resonant period, or vibrational as the "free" side of the belt starts to vibrate.
A recording of the sound might help with diagnostics.
atomarc
Mar 16, 2009
Eureka, CA
To my knowledge, HTD profile belts/pulleys use a recommended tension that one would not think appropriate..they run loose. Is there a chance you have over tightened the drive, and that could be your problem.
Worth looking into.
Stuart
jroddds
Apr 16, 2020
Worth looking into.
Stuart
Seems like an easy thing to check. I will get back with any updates.
dgfoster
Jun 14, 2008
Bellingham, WA
Worth looking into.
Stuart
Interesting idea. I could see how over-tensioning might cause poor seating of the teeth in the pulley grooves with teeth hanging a bit on the opposite sides of the grooves on the “upstream” and “downstream” sides of of the pulley. It could be interesting to spray a little paint on the grooves of the pulley and run it tight and spray and run it again at proper tension comparing the observed wear patterns, especially if Stuart’s suggestion is the answer.
You did not say so, but I guess most of us assume the toothed pulley eliminated the slippage?
Denis
BoxcarPete
Nov 30, 2018
Michigan, USA
Without intending to insult your intelligence, double-check your set screws. A set screw standing slightly proud will slap the belt each time it goes around, and could be another possible driver for the "harmonic" frequency you see. Ask me how I know :(
Easy to take a look, anyway.
jroddds
Apr 16, 2020
Sorry to leave you all hanging. I adjusted the tension on the belt by loosening it. It did help, somewhat. but vibration remains. Took the belt off and confirmed that running the motor/pulley without a belt produces zero vibrations. I continued adjusting tension tighter and looser and got the vibrations down, but the belt was far looser than I would expect.
To answer other questions:
The pulleys are 108 teeth on the motor and 50 on the spindle.
There are no set screws on the teeth. The motor has a set screw on the hub, the spindle does not have one.
Timing pulley did fix the slippage issue (for sure).
I may try the painting idea to see where it goes. Otherwise, I just got a new pulley in the mail. Will see if swapping for a new pulley provides any results.
CarbideBob
Jan 14, 2007
Flushing/Flint, Michigan
I'd be tempted to put a DTI on the backside of the belt at the max contact area (back of the pulley) and look for runout.
One can not just indicate the pulley as the peaks do not matter.
You can mount a very cheap USB camera/microscope and watch the profile pass for runout but if the tooth spacing messed up the vibration will still be there as the belt climbs and drops.
Have you considered that maybe the belt tooth spacing is bad at one spot? Not an often problem on good quality ones but it does happen.
Tried more than one belt?
Bob
HappyWyo
Nov 30, 2019
It would be nearly impossible to eliminate all vibration when using a toothed belt. Take a toothed belt in your hand, bend it and slowly roll it. Notice the tooth portion is ridged and the void portion bends easily. Now imagine that happening at high speed.
jroddds
Apr 16, 2020
Just to provide some resolution: I changed the pulley out for a new one with a taper bushing (instead of a set screw) and it runs much smoother now. Must have been have been a bad pulley on the motor.
Thanks for all the insight.
gustafson
Sep 4, 2002
People's Republic
Thanks for getting back, it really helps future readers
