VINTAGE BROWN & SHARPE USA NO 25 MICROMETER
  • Thread starter Thread starter Scott S
  • Start date Start date
  • Replies 16
  • Views 701
Scott S
Jul 7, 2024
New York
I have what appears to be an extremely rare vintage micrometer made by Brown & Sharpe in early 1900s. It is a No.25 Direct Reading Mechanical Digital Micrometer with a very unique readout system. I hope someone will have more information about this unit. I have only found 1 photo of one, and that was from about 10 years ago.
Thanks
Scott
Old tools are best discussed in the antique section. My 1922 B&S catalog has the No. 26 digital mike, but not the 25.
Larry
Thanks Larry, every bit of information helps to fill in the gaps in what I know. The 1922 B&S catalog helps confirm that it was discontinued before that, making it over 100 years old.
Scott
I have two, both broken.
Ingenious design, beautifully made, hopelessly delicate.
There should be a key which slides in the keyway just visible in the alloy sleeve, with a peg on one end which engages with a cam groove. I think the problem is that they wanted to minimise the diameter of the alloy sleeve, with the result that the key/cam was far too thin and flimsy to survive.
Thank you for your post and photo of the internal parts. It makes it all the more amazing that the one I have is fully functional.
Thanks
Scott
I also have a #25 but is currently not functioning correctly. There is a small pin with string attached. Not sure where it goes. I inherited this, and a depth gauge also from an old inventor named R. Royal. I also would be interested in vintage and possibly how to repair this.
Skeeter,
That's interesting. I haven't seen one of those little keys. They were missing from both my examples.
I figured out what was needed, and made one as an experiment out of mild steel. I filed it to shape, to slide in the keyway in the aluminium sleeve and to engage in the cam slot and notches (features visible in my photo, post #8). In fact I made two - I dropped the first one, and gave up trying to find it!
I thought it was a reasonable fit, but it was too weak (and probably inadequate, fit-wise) and immediately got chewed up.
Perhaps the previous owner of yours bought a new key from B&S, but then decided not to bother.
As someone who has also struggled with broken No. 25's, I appreciate the excellent photos supplied by Asquith of the innards of this micrometer. And thanks to SkeeterFX21 for the photo of the pin. If possible, can SkeeterFX21 provide a couple of close up photos of the pin that accompanies his example? Thanks.
I have some that work and some that don't. I have taken them apart and made the missing or broken parts but that was years ago and I don't remember any of the details. Guess I need to fix some of the broken ones.
