Vintage Clark Forklift
jerry13
Feb 25, 2021
We have this 65 or 66 Clark Forklift.
No tag and no serial number on frame.
The counter balance is 8" in the center.
Could it be a C20, c25, c30 maybe?
If anyone can recommend an engine rebuilder for the flat 4 in this forklift in the Austin area I would appreciate it.
Thanks
Clark - Album on Imgur
dalmatiangirl61
Jan 31, 2011
BFE Nevada/San Marcos Tx
Thanks
I could not get your link to open. Quite honestly if engine is dead and needs rebuilding, its probably not worth it, even if you do the work yourself, either find a used engine, or give it last rights and call the scrap man.
dalmatiangirl61
Jan 31, 2011
I'll try this again.
Your link is not working for me. I have serious doubts that rebuilding the engine, especially if you farm it out, is going to be economically feasible, either find a replacement engine, or give it last rights and call the scrap man.
gbent
Mar 14, 2005
Kansas
Thats a cute little guy. Looks like a solid aluminum steering wheel with a factory Brodie knob. Gotta love the air scoops on the sides. If you can change the engine yourself, check with Grindstaff Engines for a rebuilt engine.
jerry13
Feb 25, 2021
Pics
NWSG4bV
john.k
Dec 21, 2012
Brisbane Qld Australia
That is a cute little lift...and well worth fixing ,too.....Its got a set of near new cushion tyres....at least $1000 worth ........OP says its a "flat four" assume he means flathead Continental F164 or the like.......There is no need to rebuild the engine like you would a car or truck......just fix what ails it and it will run for years puttering about......At worst ,a set of new rings,new valves and a block and head face,fix valve seats ,and a electronic ignition,it will be good as new.
Jstrausser3303
Apr 27, 2023
Thanks
If I remember correctly the chrome louver on the end of each side door was a 66 year thing only. Machines a c-30 or larger with the horizontal tank mount like you have. I feel like it looks longer then my c30 but could be wrong
FamilyTradition
Feb 24, 2018
Greenfield, Mass
We have a vendor that has one of these, with the chrome bits on it as well. If I get the chance i will ask if he knows the year of the lift itself.
His has an engine from a '74 Ford Pinto in it. I don't know what went into modifying motor mounts, transmission, etc, but it is obviously possible if you set your mind to it!
