Visibility of the puddle Tig Al vs Tig SS
mjk
Oct 20, 2005
Wilmington DE USA
I'll be the first to admit I am not a professional welder.
I do a few hours a week of mig w/steel with good results, in my past life I was involved in large vessel fabrication
I've had a Precision tig 225 for 18 years and up until 6 years ago was using it a few hours a week for aluminum and stainless (air cooled torch)
Any work I do is considered non critical or has any safety implications if failed.
Absence to tig was due to a variety of issues, but in the mean time I had picked up a Square wave tig 350 with water cooled system for a good price.
Within the last month have needed to weld some 304 SS similar to what I've welded in the past, decided to try the "new to me" machine with the water cooled torch
Along with my experience level I have 66 year old eyes. I seemed to have more of a problem seeing the puddle.
Not wanting to screw up the part, I decided to practice more.
I had bent up some aluminum trays 1/8" center sections with 1/2" end caps and decided instead of mechanically fastening I'd weld them to build up practice .
I see a huge difference with my seeing the puddle and surrounding area
using pure tungsten (green) with the aluminum
using 2% lanthanated tungsten (blue) with the SS
So should I see a difference in the puddle with the different metals, different tungsten and DC vs AC?
Bondo
May 14, 2011
Bridgeton NJ
Aluminum tig welding gives off a very bright arc. Stainless and steel have a much dimmer arc looking at it from under the hood perspective. It's basically the same as saying looking at the sun directly is alum welding and having sun glasses on is steel and stainless welding.
You may need to go down 1 shade for the steels compared to alum on your helmet.
Cheeter lenses work great from what everyone else says. I'm 40 so I need to start aging attention to this stuff.
DrHook
Oct 8, 2013
Pierre
I have a cheater in my hood, and sometimes wear reading glasses as well, if I need to get my face close. The two materials will also look different through the lens, so darken the shade for aluminum, as was already stated.
turnworks
Dec 12, 2018
AC aluminum the actual arc is much bigger(spread out) than DC stainless coming from the tungsten along with normally larger arc gap. Thats probably causing the difference you are seeing. When welding aluminum I'm so dang focused on watching the impurities in the puddle I don't even notice the surrounding area.
akjeff
Nov 17, 2008
AK
I just use 2% Lanth for everything. Aluminum puddle seems reasonably visible to my 58 yo eyes( as long as I remember to wear my cheaters!).
Trboatworks
Oct 23, 2010
Maryland- USA
I am using one of the Optrel true-color helmets with a 1.5 cheater.
These are nice helmets and I have no issues with puddle clarity plus they have a useful features set.
Expensive kit - I think this was around $550 from supplier:
seiner
Jan 9, 2008
Valdez, Alaska
For aluminum and welding in general I need really good lighting. the bright arc in contrast with poor lighting just cause problems for me. Im often in poor locations on boats so drop lights, make me happy.
my best one is a four foot led "shop light" that i wired to a good cord.
plastikdreams
May 31, 2011
upstate nj
Found out haynes 230 gives off a bright arc too
mjk
Oct 20, 2005
Wilmington DE USA
2nd the Optrel true color
I have the one with forced air hepa filter, keeps the fogging down, keeps the air clean
also have the grinding shield that uses the same air pack
gift from my wife a few years ago after a discussion about SS weld fumes and her seeing me clear the black creepy crawlers from not using a breathing filter/mask ( she's a good one)
I think some experimenting with other than auto settings will be needed for SS
I've tried my readers but didn't seem to help much, and made me dizzy
re adding additional light, is that mostly to help until the arc starts?
I would think shop light/drop light wouldn't add that much
BT Fabrication
Nov 3, 2019
Ontario Canada
It’s all in how good your helmet is….
And how clean you keep it.
More amps= darker lens settings.
Backlight is worse as it causes reflection inside the helmet.
Ambient light in front is better but never really happens.
I have mine usually about shade 11 or 12 for everything.
If you want more light, buy the glass cups, they aren’t cheap and don’t handle super high heat on ac either over 225A.
I get more issues with glare inside my helmet from behind me and occasionally the leds in the shop cause my helmet to do weird things on low amps.
mikeylikesit
Sep 1, 2022
if ya know how to weld ,ya know how to weld. if ya dont ,ya dont.
if your no good with brand x helmet ,you still wont be any good with brand z.
keep the front cover plate clean. use a fabric cover on the rear.
cheaters magnify like binoculars.
in low light you may need a drop light or some helmets have attached work light
Scruffy887
Dec 17, 2012
Se Ma USA
I have cataracts and am glad to hear about Optrel opinions from others. I talked with them a few weeks ago and their US HQ is very close to me, told me to come on in and see what fits and works best. Going to do that.
scsmith42
Jul 28, 2020
New Hill, NC
I’ll also jump on the Optrel bandwagon. My Crystal 2.0 is remarkedly better than all other hoods that I’ve tried.
For the OP, I’d suggest three things. First - a better hood. Definately check out the Optrel offerings.
2 - add a cloth light shield to the back side of your hood. I took some green welding cloth and attach it with Velcro to the top of my hood. It drapes down to my neck and stops all light from entering behind the hood.
3 - put a bright light on the area to be welded.
These three things were a great help to me as my eyes aged.
gustafson
Sep 4, 2002
People's Republic
I always had trouble seeing the aluminum puddle. I just sit there and tap it with the filler rod till it jiggles. Stainless no big deal
and I am blind as a tick. magnifier in the helmet, readers on light over the table
mikeylikesit
Sep 1, 2022
this light is brilliant. made specific for the helmet and powered by the adflo battery. frikin genious
Journeyman Jim
Mar 1, 2023
Try welding with another known plant to fiddle with your helmet settings. I've settled on red for ss and white for ally, your other tungsten's will do both however.
A quick Google of the manual and it seems a solid Lincoln welder, no8 is "cleaning vs penetration" and 15 is the wave shape. For want of layman's terms I would start fiddling there
