MilGunsmith
- Mar 6, 2006
- Sandyston, NJ
Can you post info on the light? I have the same helmet with the PAPR.this light is brilliant. made specific for the helmet and powered by the adflo battery. frikin genious
I second the suggestion to add cheater lenses. They help older eyes see more detail. You might also want to add bright work light(s).Aluminum tig welding gives off a very bright arc. Stainless and steel have a much dimmer arc looking at it from under the hood perspective. It's basically the same as saying looking at the sun directly is alum welding and having sun glasses on is steel and stainless welding.
You may need to go down 1 shade for the steels compared to alum on your helmet.
Cheeter lenses work great from what everyone else says. I'm 40 so I need to start aging attention to this stuff.
I'll sort of ask again
Is the additional light for prior/post arc strike?
Spoken like someone with no vision problems!if ya know how to weld ,ya know how to weld. if ya dont ,ya dont.
if your no good with brand x helmet ,you still wont be any good with brand z.
keep the front cover plate clean. use a fabric cover on the rear.
cheaters magnify like binoculars.
in low light you may need a drop light or some helmets have attached work light
How about this statement instead: If you can't see the puddle clearly you can't weld.
I used to be that guy the old guys would ask to read the tiny print. Not no more.
I'm just getting back to welding after many years away. Now my old eyes wear trifocals. Before I could see exactly what I needed to see, and was frequently complimented on my welding.
Now it's very frustrating to see the puddle clearly in all positons. The reading part of the trifocal is not always in the right place. Cheaters will help I'm sure but I've not got one yet.
Surely there is a difference in quality between harbor freight and top line. I'm sure every little bit of additional optical clarity will help.
You may have glaucoma coupled with cataracts. I repaired boat props for years welding thin prop blades with a lincoln 300 air cooled torch with thumb .control . I have glaucoma and that killed my welding . I had lens replacement to fix the cataracts which helped but I still have a problem with the glare on the arc which hides the pudddle. You might try some poloraized sunglasses inside your hood , that will dampen the glare and make it easier to see the weld puddle . Gettn old is no fun ---at allI'll be the first to admit I am not a professional welder.
I do a few hours a week of mig w/steel with good results, in my past life I was involved in large vessel fabrication
I've had a Precision tig 225 for 18 years and up until 6 years ago was using it a few hours a week for aluminum and stainless (air cooled torch)
Any work I do is considered non critical or has any safety implications if failed.
Absence to tig was due to a variety of issues, but in the mean time I had picked up a Square wave tig 350 with water cooled system for a good price.
Within the last month have needed to weld some 304 SS similar to what I've welded in the past, decided to try the "new to me" machine with the water cooled torch
Along with my experience level I have 66 year old eyes. I seemed to have more of a problem seeing the puddle.
Not wanting to screw up the part, I decided to practice more.
I had bent up some aluminum trays 1/8" center sections with 1/2" end caps and decided instead of mechanically fastening I'd weld them to build up practice .
I see a huge difference with my seeing the puddle and surrounding area
using pure tungsten (green) with the aluminum
using 2% lanthanated tungsten (blue) with the SS
So should I see a difference in the puddle with the different metals, different tungsten and DC vs AC?
Thanks, I will talk to supply.
.....2 - add a cloth light shield to the back side of your hood. I took some green welding cloth and attach it with Velcro to the top of my hood. It drapes down to my neck and stops all light from entering behind the hood.
3 - put a bright light on the area to be welded.
These three things were a great help to me as my eyes aged.
Make sure you aren’t seeing spot’s after welding. 10 is a minimum for arc welding,12 for silver metals.I'm actually on a "detached retina watch"
10 years ago after the eye doctor removed a small steel sliver in the surface of my eye she found a small issue that required bi yearly monitoring. Exam entails a light almost as bright as catching an arc strike as my eye lids are stretched wide open .
Fortunately cataracts are not an issue...yet, and ironically the spot being monitored which could lead to a detached retina has gotten better not worse.
And I have asked multiple times about welding affecting my eyesight as in my previous life as a welding inspector our shop had some guys that weren't considerate of others in the area. Only had maybe 3 bad sand storms at night, but no damage.
Whats it take to set a weld curtain up.....
I can see the puddle and surrounding 3-4"s around the puddle clearly welding aluminum
As I mentioned above, having my setting on auto (12 )when I should have been around 9 or maybe evan 8 with the SS is most likely the issue.
Hopefully next week I'll have time next week to confirm about the ss
what are you basing this on?Make sure you aren’t seeing spot’s after welding. 10 is a minimum for arc welding,12 for silver metals.
When they first came out, all the "cool kids" had to have them- they were gonna save the welding world. I tested one and wasn't convinced it was worth 2-3 times most name brand hoods so I didn't buy one. When I got my current job, there was one here, and I tried to use it, as it was "free", but did not like the small size, heaviness (compared to my own) or electronics, especially if I had to step outside.does nobody weld outside ? i bought the e684 and franky started to hate it more and more as time went on so i got rid of it. wasnt even usable outside as the sun trigger the sensors immediatly. adjustment knob orientation and location i didnt care much for either. rechargable battery ? ,no thanks i want no part of that.
the panoramax ive seen a few people say the thin center section of glass breaks.
not trying bash optrel but it seems theyre way over hyped if you ask me.
people convinced me to buy one before i knew any better. never again
Notice
