Wanted: Rockwell Horizontal Overarm Ram and Arbor Support
StanF
Jul 1, 2016
Yeah, I know this will be tough to find, but I'm an optimist! :cheers:
Need the overarm support and the horizontal ram for a Rockwell Horizontal Mill.
The ram is 3.125 OD and about 23" long. The arbor support is a casting that is shown pretty well in the attached photos.
I'm located in Texas, so hopefully local. Or someone who is willing to ship.
22318-1-z - Copy.jpgarbor support bracket pic.jpgarbor support bracket pic1.jpg
Good luck on your search. I tried and failed to find them so I made them.
3.250" turned down and a 2" slab reshaped ,with a bronze bearing and a gits oil cup.
If you go this route. I went with 24". It works but an inch or 2 more would keep the bar completely in the back clamp when changing arbors.
Hydraulic repair shops could be a source for a rod @ that size that was replaced during a ram rebuild .
animal
View attachment 442121View attachment 442122
Nice work! Machining a replacement was my first thought, but I'm also considering making a pattern for a casting. More for fun than for improved function. Thanks for the tip on the ram length!
Where did you find the steel? I've been looking, but it's about $200 or more for a new, solid round 3.25 OD.
3-1/8" should be available in TGP or chromed hydraulic rod, I may have some in cold finished, but TGP would be a lot nicer.
Your local steel yard won't be too eager to get you any at your needed length, try online sales, machine shops or hydraulic shops. ( eBay too)
At 26.1 lbs per foot, $100.00 per ft is pretty close to normal for new 4140. Hot finished Q&T should be less expensive if you don't mind machining it to size.
On that support, custom is likely your best option.
At the time I was searching there was a support bracket on Ebay... and the buy it now price was nearly $100 with shipping.
I got the steel from a local shop. The local Home Shop Metal Club worked out a deal .. They offer a discount to Valley-Metal members.
In pre zombie apocalypse era it cost me just under $100 for the 2 hunks of metal.
On other thing to think about...is arbors.... the 3 I bought new came from Sears or Kmart online. They were from Poland and were in the $40 to $50 each range. The bad part about that was it seemed like they walked to the US from Poland. 4 plus months as I recall. The new 7/8, 1, 1 1/4 arbors worked with the older tooling I have hoarded over the years...
Unfortunately new Chinese involute gear cutters are 22 MM. I bought a used arbor and turned it to 22mm to use with the new cutters. Which are hit and miss for usability. Even in the same set.
Thinking about my Rockwell reminded me where it came from.
Who knows how many years it was the sign for Moore tools until they left the Virginia address.
https://www.google.com/maps/@33.476...01T000000!7i13312!8i6656?coh=205409&entry=ttu
Thank you John
That's an awesome sign! I guess it's dry enough in Phoenix that it didn't damage the machine.
I picked up a couple of arbors already - 1" and 7/8". Both new from Poland. One was from KBC and the other from eBay. They aren't cheap ~$200 each, but they are available. And they come with spacers, nut, etc.
I might turn down the 7/8 to 22mm, so thanks for that tip. Or bore out the cutters? I've got a ways to go before I get to that point!
Is a 1-1/4 arbor useful? I guess it depends on the cutters that you have. I might try making one for fun. I've also seen people use a CAT 30 Endmill holder to make the arbor machining easier and faster. So, I could try that technique too.
I thought about boring and maybe broaching the cutters and decided to alter one arbor instead of every new cutter I might want or need.
The 1 1/4 arbor was bought for a collection of larger cutters.... The projects I do just havent needed much big stuff. It has been used a couple times.
I bought the Rockwell cause it uses the same tooling as my Famco . 2 mills one set of tool holders, drill chucks and boring heads.
The few times I have used regular NMTB30 tooling in it have all been nice. I havent needed to line up a couple right angle plates to hold stuff on the Famco... just clamp it on the Rockwell and go to town...
