kustomizer
- Aug 17, 2007
- North Fork Idaho
If it moves and it shouldn't, use duct tape, if it doesn't move and it should, use wd40, so says my sister the Chiropractor.
I bought a new Baldor carbide grinder about 45 years ago when I began using carbide tools.
Then I got a good used Leonard Grind-R-Lap and cleaned and painted it. I liked it better than the Baldor for most work. A few miles from me, Continental Diamond Tool, New Haven, IN, made me a pair of laps for it using my steel rings. Worked great for brazed carbide and extending the life of inserts. I very seldom use the Baldor anymore. The Baldor is single phase, so no way to slow it down with a VFD.
Then, years ago, I got a new Glendo Accu-Finish and stopped using the Leonard. After using the Accu-Finish, I stopped looking at carbide grinders, though I did buy a spare Accu-Finish to get the additional wheels it had.
I turned the Leonard on just now and noted the lateral motion is not working (it used to). Maybe I will turn it over and look in the bottom to see what got stuck.
Larry
My Ohio grind-r-lap machine showed up today, it looks good though there is some assembly required and I will likely look at that this weekend., Thanks Mike
The other one is heading this way from Oregon and should be here in a couple of days.
Glad it made it, assembly is two pins and bolt as I recall. The light included wasn't wired up. Hopefully you are happy with it.
