Warner & Swasey #3 M-1200 List of Oil, Grease and LUBRICANT's to use.
CRJarvis
Apr 23, 2017
Headstock oil is MOBIL DTE MEDIUM,
(ISO VG 46 MINERAL BASED R&O OILS)
MOBIL DTE MEDIUM
MOBIL DTE MEDIUM | 5 GALLON PAIL
Mobil / 101057
$86.94
(Other - ISO VG 46 MINERAL BASED R&O OILS)
CHEVRON REGAL R&O ISO 46
CHEVRON REGAL R&O ISO 46 | 5 GALLON PAIL
Chevron / 273210448
$69.90
76 MULTIPURPOSE R&O OIL 46
PHILLIPS 66 MULTIPURPOSE R&O OIL 46 | 5 GALLON PAIL
Phillips 66 Lubricants / 1074242
$62.95
SUNOCO SUNVIS 946 TURBINE OIL
SUNOCO SUNVIS 946 TURBINE OIL | 5 GALLON PAIL
Sunoco Lubricants / 437305
$39.22
COASTAL R&O HYDRAULIC OIL
COASTAL R&O HYDRAULIC OIL | 5 GALLON PAIL
Coastal / 46009
$32.36
International Standards Organization Viscosity Grade 46 Mineral Based Rust and Oxidation Resistant, Bearing Lubricant
Way oil is mobil vactra #2
(ISO VG 68 | SLIDE WAY LUBRICANT)
MOBIL VACTRA OIL NO. 2 | 5 GALLON PAIL
Mobil / 105480
$88.45
(other - ISO VG 68 | SLIDE WAY LUBRICANT)
CITGO SLIDERITE 68 CROSS REFERENCE Citgo Sliderite 68 Cross Reference
CHEVRON WAY OIL VISTAC ISO 68 | 5 GALLON PAIL
Chevron / 232511448
$72.80
PHILLIPS 66 MULTI-WAY OIL HD 68 | 5 GALLON PAIL
Phillips 66 Lubricants / 1074251
$63.20
SUNOCO HD WAYLUBE 1180 | 5 GALLON PAIL
Sunoco Lubricants / 675305
$40.30
ISO VG 68 | Slide Way Lubricant
grease is "NLGI type 0". my book says with Moly = molybdenum disulfide.
SCHAEFFER'S 274 MOLY E.P. SYNTHETIC PLUS GREASE NLGI #0 (1 TUBE)
Schaeffer 274 Moly E.P. Synthetic Plus Grease NLGI #, #, #1, #2 (1 tube)
make sure to pick the white cap, NLGI #0
the only other place to get #0 Grease is
NLGI Grease | Shop Now
and only in 35 pound Pails and does not list moly in it.
MOBILUX EP 0 | 35.2 POUND PAIL
Mobil / 103209
$97.95
PHILLIPS 66 DYNALIFE L-EP GREASE, NLGI 0 | 35 POUND PAIL
Phillips 66 Lubricants / 1073957
$96.89
Service Manual
http://vintagemachinery.org/pubs/2261/3760.pdf
Made this list to help everyone out if they have a question about what to use. Calvin B helped with the info, Mr. Calvin if anything is Wrong with this list please let me know so i can Fix it.
CRJarvis
Apr 23, 2017
1st Headstock oil is MOBIL DTE MEDIUM, "Gen purpose Hydraulic and lubrication Oil" No. H-10.
Schaeffer Manufacturing Co. Schaeffer Oil | Synthetic Motor Oils, Engine Oils, Diesel Fuel Additives, Industrial Lubricants Manufacturer from Tech Department 112 ISO 46
Buy Schaeffer Oil | Schaeffer Oil Full Line Of Products For Sale Online
MOBIL DTE MEDIUM
Mobil / 101057
$86.94
Chevron / 273210448
$69.90
$62.95
$39.22
Coastal / 46009
$32.36
2nd Light Slideway Oil N0. H-20
Schaeffer Manufacturing Co. Schaeffer Oil | Synthetic Motor Oils, Engine Oils, Diesel Fuel Additives, Industrial Lubricants Manufacturer from Tech Department 160 ISO 68
Mobil / 105480
$88.45
Chevron / 232511448
$72.80
$63.20
$40.30
3rd is the "Adhesive pressure Grease No. H75" ( no info on this yet.)
4th is the "Moly Grease No. H80" (no info on this yet.)
Mobil / 103209
$97.95
$96.89
Service Manual
CRJarvis
Apr 23, 2017
ok looking for the 3 jaw chuck installation help. like what torque specks do you use. will be looking up the bolts to see what they are.
