Picked up a used Omax 2652 on the “cheap”. It’s been a bit of a money pit but finally running. It came with an SRS but no SRS hopper. As well as a closed loop system but no chiller. So far we are just running open loop, it’s winter time so the city water is plenty cold, and we only have cut 8-10 hr it’s first week.
I don’t know much about the machines other than I can program them and we have work for one.
The stock plumbing doesn’t quite make since to me.
Its dumping the ADO water into the weir tank. That water is hot enough to make a coffee after it stops cutting. It would seem in summer that water should go straight to the drain to keep the shop cool. In the winter it should go to a heat exchanger to heat the shop but still not to the weir as that water would eventually need cooled if running closed loop.
The other thing that doesn’t make since to me is why Omax designed the SRS system like they did. It seems like another big settling tank. Maybe they work real well? We haven’t actually used ours yet but have 500lb of garnet in the tank already.
A company called Lakos makes centrifugal water filters that look like a perfect fit for waterjets. They come in a variety of sizes and configuration with a couple looking ideal for waterjets. Supposedly they’ll get below a 50 microns particle size on the high end filters and can be fitted with automatic dumps when the get full.
Has anyone used something like this or is the Omax set up the way to go?
