Andrew.Bird
- Mar 13, 2018
- Portland, OR
We have several Fanuc Robodrills using 31i controllers that have an issue with the work offset measure function. The machines all run in inches, but when you measure something, it inputs the number into the work offset as metric. But what is even more weird is if you convert the number to inches, it isn't correct, it's obviously off several inches.
The only way we have found to get it to work is to go to the settings page where you turn on/off PWE and change the parameter for Input Unit to mm, then measure, then switch the parameter back to inches, which switches the work offsets to inches as well.
Not my picture, but this screen:
Adding to the weirdness, The Absolute and Relative position readouts are in inches, but the Machine readouts are in mm.
Anyone have any idea what is going on?
