kerrigan007
- Apr 3, 2023
Hi all!
I'm new to the site and I'm hopeful some of you can have some leads on my current problem. I apologize in advance if I'm not clear enough, since English is not my first langage.
I'm machining a part that is about 42 inches long, 1.218 wide. Both sides are radiuses, slightly different (167.786 inch and 169.014 inch). We rough the part with a 2-inch cutter, then finish it off with a 1/2 endmill. I can put a negative tool compensation on the cutter without any problem. As soon as I try it on the endmill, it cuts the radius wrong, even if it's only -0.0001 as a compensation. I end up with measurings like 1.210 at both ends, and good measuring at the center only. Without any compensation, everything is fine so we know the program is correct. We tried many things so far. We got the backlash fixed last week with a company that aligned everything with a laser. Parameters for the backlash are ok. We think it's another parameter, but we don't know which one. This problem occurs only with 1/2 endmill and nothing else.
The machine is a Mazak V655-60 with Mazatrol M plus control (made in 1996).
Any ideas? Next step is to hire a Mazak guy...
Thanks.
Thanks.
