Yesterday a customer (another shop) called in sort of a panic. He had dropped an antique Harley cylinder and broke a cooling fin off and needed it repaired immediately so he could finish the job before his customer came. About a 4" weld. He dropped it off and went out for lunch, and I had it done before he came back. No, it didn't go "TINK" and I dusted the bead with a flap wheel, and it blended in nice, customer was happy, and I made some quick cash.
I would like to share how I did it, but last week eKretz told everybody here that I had no idea what I was talking about and basically don't know shit, so I guess I'll keep my technique a secret? Too bad because maybe someone else could benefit?
Thin skinned a little? I only called you out on the big diatribe about how preheating and slow cooling was totally unnecessary. And how nickel rod is useless for cast iron welding. You know, that part where you basically said everyone who does that has no idea what they're talking about and only does it because old timers used to? About that, you apparently
don't have any idea what you're talking about. That's all I was referring to. Other than that I don't know you from Adam; nor whether you're FOS on other subjects. I
can tell you I've done literally what must be close to a hundred repairs on cast iron structural items like connecting rods, rams and similar parts in punch presses and even a few "unobtainium" cast iron dump truck wheel hubs over the last thirty years, which are about the most severe environment there is for a weld repaired cast iron part, and I have had ZERO failures using nickel rods, good preheat and slow cooling. With readily machinable weld afterward.
Anyway, there's no secret to welding iron. There are a few methods to do it that will work, and they have mostly already been discussed here. Welding in short bursts to keep the part cooler and prevent a lot of expansion and contraction is no secret. I sure wouldn't use it in a critical structural repair though. Welding a cooling fin back on is not in that category. It didn't go TINK, and likely won't - unless someone bumps it with a little bit more than it can take. if it wasn't slow cooled it will have basically zero ductility in the area of the repair.
Gotta love these guys that claim to know all this secret crap, can't stand that shit. But I digress.
