From your description i think an older traditional heavily built slider like a Tannewitz XJS or JDR, Wadkin, Greenlee, Oliver 260D, or other traditional all CI machine that was built for making small complex pieces from solid lumber stock would be your best match. These saws were designed for that process before plywood was a thing.
Modern long stroke sliders take up a lot of real estate and are optimal if you use them mostly for panel products.
(I think that is dumb, too - if you need a panel saw, get a panel saw) IOW, the modern machines are another version of the one machine does it all approach, but is not necessarily optimized for solid wood small parts. All the parts are aluminum. I can say that whenever i've built fixtures to optimize use of my SCMI slide for small solid wood parts, they are steel and CI. It makes a difference.
The traditional sliders tend to max out with strokes around 30" to 36" so they really are not panel saws in the modern sense if you need that capacity.
They also are mostly direct motor drive, so often do not have deep cutting capacity even with 16" blades if that is a factor. If you prefer to carry a part fully past the blade rather than retracting the table as soon as it is severed, 32" travel, say, limits width of a 1" thick board to around 20"
I'd still like an XJS with all the bells and whistles since complex small hardwood parts are (or used to be) a large part of my production.
I think a saw like that or the Oliver 260 D were the pinnacle for small complex hardwood parts other than dedicated set ups with auto cycles.
However, before one ever showed up on my radar, my compromise was a cheap SCMI Si 15. These turn up fairly commonly for less than $1,000 since they are limited for a modern panel shop. OTOH, be sure all the fences, carriage, and stops are there and that it is not beat to death.
These & similar sort of "transitional" Euro saws have strokes around 50" to 60" for cross-cutting panels, but are all CI except the fences.
Being belt driven, a 16" blade on mine with cross cut a 6x6 with some height to spare. 3 speed options (belt ratios) allow blades as small as 8" or similar size dado sets to be effective. The only real drawback is that the sliding table is quite distant from the side of the blade. Traditional sliders and modern panel sliders put the edge of the table right beside the blade, and allow that section to be shifted in or out to accomodate blade thickness or dados. So on my saw, sometimes for small parts, i do end up bolting a sub-table to the sliding table T-slot, that reaches to or past the blade.
smt
