I am attempting to establish some baseline expectations for expected lead times the company I am working for. I know a we can get lost in the weeds of how complex a singular part is that may affect the whole, but I really am attempting to keep things as simple as possible.
One of the parameters that may shed some insight onto the base lines I am proposing are the following: I work in an R&D environment which is heavy on the Research element, and secondary to the development. We have many fresh scientists and only 2 mechanical engineers which are also fresh, but very bright fellows. We have very little in standardization which is why I am trying to establish some now hopefully with some extra help from you fellows. Lastly our Design reviews are a bit of a joke, coworkers in the same project will "review" each others work (but that is a separate tangent).
I would be very curious to find out what you guys think of this proposition and what I may want to really include/exclude.
For Simplicity and Clarity I propose 3 levels of complexity for a project that may run through the shop.
Simple: that being a maximum of 2 components that have interaction. This would include no features that are beyond very basic DFM parameters (Think protolabs design guidelines). Tolerances can work from all parts being block dimensions.
(quote for each part is sufficient for baseline estimate)
Semi-Complex: That being a maximum of 4 components that have interaction. A maximum of 2 features may be beyond the basic DFM parameters. Some GD&T maybe required to ensure fit. Maximum of 3 tolerances may be beyond basic block tolerancing to ensure intended interactions.
(a minimum of 1 1hour meeting is to take place to ensure features do not conflict and are necessary before any quoting of job can begin)
Complex: That being a maximum of 7 components that have interaction. Features may be beyond basic DFM parameters. GD&T is required to ensure fits. Tolerances maybe beyond block tolerancing to ensure intended interactions.
(a minimum of 3 1hour meeting is to take place to ensure features do not conflict and are necessary before any quoting of job can begin)
Justification for each are as follows.
Tolerance is a fundamental aspect of machining and assembly. When tolerances can remain basic with intended interactions simple assemblies can be created quickly and easily, but as tolerancing becomes more specific and constrained (think limits and fits) the complexity of the whole assembly increases - not in a linear fashion but in exponential.
GD&T is the next step in fundamentals when it comes to machining and assembly. When GD&T requirements are applied to a part the whole has to be remembered. The more GD&T that is applied to features to ensure fits to more we have to do in the shop to ensure when a part is complete it will interact with its intended mating feature.
Number of Parts as this grows so does the level of complexity. once again this dose not grow in a linear fashion but in an exponential one. More analysis should be taken before processing will even begin. The amount of time and money to create a 7 component assembly for it to need rework or to flat out fail is exponentially higher than an extra 3+ hours over a weeks spread hammering out the finer details of an assembly.
Again trying to keep it as simple and straightforward as possible.
What do you guys think? Would this be an okay starting point for shop expectations? anything you think I should add or really hammer home?
