What have you made FOR your South Bend?
paulsomlo
Oct 15, 2009
Colorado
A threading dial for my 9a.
I made the gear from nylon using a fly cutter on a horizontal mill w/indexer. The teeth are cut straight, the mounting stud is press fit into the aluminum body at the helix angle (3 deg), tilting the entire threading dial to match the lead screw. I haven't engraved any numbers onto the dial face and may not. If I ever have to cut a fractional thread, I guess I'll just mark one of the lines with a Sharpie.
Paul
aametalmaster
Jan 11, 2005
Salem, Ohio
A few pics with 5 projects for the lathe.
This is how i usually work with my lathe and the home made stuff i use on it. First is a lathe dog plate to spin my welded up lathe dog. Then the taper attachment to cut the angle of the #2MT to be used as a tailstock arbor. Then my square toolblock. Anyone need more info just pm me...Bob
aametalmaster
Jan 11, 2005
Salem, Ohio
Home Made Taper Attachment..
Here is my 20 dollar taper attachment in action cutting some #2 MT arbors. I have lots of how to make it pics if anyone is interested. The cross slide srew is removed so the cross slide floats on the sine bar....Bob
taper att.avi - YouTube
Lance1586
Jun 27, 2010
NE, USA
Bob, I am a newbie still in the process of rebuilding my little workshop Model B 9". But I am also interested in the plans for your taper attachment if they are available I would greatly appreciate it. I think some form of this will be the second project for my machine after a QCTP.
Thanks, Lance
CDRIVE
Aug 12, 2011
S. Florida USA
Thanks, Lance
Bob, I sure hope you saved all those bar napikins! :D:rolleyes5:
Chris
Feb 27, 2008
montreal canada
hi i would very much like to make one ! if it is possible i would like to see these how to make pictures .maybe you could email them to me( if not too much trouble ) regards .jack
bradjacob
Nov 18, 2008
Easton, PA
Since adding the coolant system I found out quick that I needed a splash guard. I made this out of 1/8'' plexi and just sandwiched it between two aluminum angle pieces.
How'd you get the plexiglass to bend?
Todd...
Dec 30, 2011
PA, Philly. Hartford
heat it up with a heat gun or torch if you are careful. torch gets it hot fast and causes bubbles if you are not paying attention. heat gun is a little more forgiving
this part is not for a lathe but you can see i formed the plexi around a mold, first one i did was by hand then i got smart and made a vacum rig
CDRIVE
Aug 12, 2011
S. Florida USA
Your motor looks out of place with old iron but it's none the less interesting. Is that a Grizzly head stock from a wood lathe? The type that has an integral motor and vary-speed?
Chris
CDRIVE
Aug 12, 2011
S. Florida USA
Well, after reading through that thread it's not exactly what I thought it was or described in my last post. I thought it was a Motor/Headstock like this.
NOVA DVR 2024 Lathe
Basically, the Head Stock is a motor with a hollow armature/spindle.
Anyway, I think what you did is very creative and exemplifies home shop expedience. I wouldn't loose any sleep over the VFD issue in that thread.
Chris
aametalmaster
Jan 11, 2005
Salem, Ohio
Reversed live center.
Here was a little job i just finished to use on my SBL when i make plumb bobs. Now i can hold the tail of the bob while i work on the body. Its just a #2MT shaft turned with a boss to hold a 608Z ball bearing...Bob
