WHat is the difference between various Hilger & Watts Auto-collimators
hkv
Aug 28, 2015
Hi,
I am considering buying an old Hilger & Watts Auto-collimator. However, I can't figure out what is the difference between the models available. I have seen:
TA1
TA3
TA53-2
TA59
Can someone enlighten med what is the difference between the models and which one to look for? I want to use it for checking surface plates (3x2) and machine ways etc.
Perhaps someone is sitting on an old sales broschure that clarifies it all. :o
ballen
Sep 25, 2011
Garbsen, Germany
Hi,
TA1
TA3
TA53-2
TA59
I am reviving this thread, because I am also interested in this question. Does anyone know the answer?
CharlyDE
Jul 11, 2014
near Münster, Westphalia, Germany
There are photographs from a leaflet:
Hilger & Watts TA3-1 Autocollimator
The informations I put into a table:
Same picture of the table in better quality:
https://abload.de/img/hw_largep8b87.png
Some of the information from the leaflet typed in:
Hilger&Watts
Microptic Universal Autocollimators
- larger aperture, giving increased maximum working distance
-2 ?/?-inch diameter telescope barrel, chromium plated and ground to permit direct mounting in vees and tooling fixures
- elemination of the image of the target draticule from the field of view
- maximum versatility
For the types 1, 3, 50, 51, 53, 57 this 4 data are the same:
- direct reading to: 0.1 second of arc
- measuring range: 10 minutes of arc
- accuracy over total measuring range: 2 seconds of arc
- accuracy over any 1-minute range: 0.5 second of arc
TA1
Microoptic Autocollimator
Displacements in two planes at right-angles are measured separately, by rotating the instrument through 90 degrees. External micrometer reading system.
maximum working distance: 50 ft
TA 3 Photoelectric Microptic Autocollimator
Displacements in two planes at right-angles are measured separately, by rotating the instrument through 90 degrees. Settings are made by rotating the external micrometer drum until a null-reading is given on a separate indicator meter.
maximum working distance: 30 ft (50 ft when used as a visual-setting instrument)
TA 53 Photoelectric Microptic Autocollimator
same as TA3, but:
Displacements in two planes at right-angles are measured separately, by rotating the eyepiece through 90 degrees.
maximum working distance: 50 ft (100 ft when used as a visual-setting instrument)
TA 50 Universal Autocollimator
Displacements in two planes at right-angles are measured separately, by rotating the eyepiece through 90 degrees. External micrometer reading system.
maximum working distance: 100 ft
+ Position of eyepiece interchangeable to permit either straight viewing, or right-angle viewing from above the intrument.
TA 51 Universal Autocollimator
TA 57 Photoelectric, Servo-Operated Autocollimator
TA 58 Photoelectric, Servo-Operated Autocollimator
TA 80 A.P.S. Autocollimator
TA 81 A.P.S. Autocollimator
TA 82 A.P.S. Autocollimator
Cheers,
Karl
ballen
Sep 25, 2011
Garbsen, Germany
Does anyone have some information about the Hilger Watts model TA121-1 autocollimator? I'd be very interested to see basic information about it, similar to the listings in the table shown in the previous post above.
fobyellow
Mar 9, 2021
