sfriedberg
- Oct 14, 2010
- Oregon, USA
I've got two tools that will oil these fittings successfully IF the damned fittings worked properly. 85% of the ball oilers on my import lathe flat-out refuse to accept oil, even under pressure and direct injection, and one of my summer projects is to get out the slide hammer and drywall screw and finally yank them all off. Some of them will get replaced with capped oilers and the rest with felt plugs. It would not surprise me to find that some of the oil passages under the oilers were never completely drilled out...
1st tool: I have a number of smallish (4 fluid ounce) squeeze bottles that take Luer Lock needle tips. I use blunt needles to spot apply various lubes with these bottles. Depress the ball with the needle tip (to the side of the ball, not straight into the ball) and squeeze the bottle. I got the bottles and needles from Small Parts before Amazon absorbed them. Still available pretty cheap.
2nd tool: Nice Swiss/German pump oiler with goose neck where I slotted the tip with a 0.045" slitting saw. Depress the ball with the tip (straight in is OK because of the slit) and pump the handle.
